Sentry Mode: Exclude Home
Medved_77
TM3 SR+ | MSM+Black | No FSD
Jan 20, 2020
1,999
1,973
Scotland
I've just set Sentry Mode to exclude my home location only. The phone app still says Sentry Mode is active though.
Is this normal or does my car not know it's at my home address?
I registered my exact address on Google Maps about 3 months ago and got an email confirmation confirming the location was updated. If it's not normal, perhaps I need to wait for the Tesla maps to update? My address was shown just a few doors down the street before though so not sure how large the home radius is?
VanillaAir_UK
7,745
5,204
Surrey, UK
If you haven't moved since setting home location only, then yes, its normal.
It probably (unless 'home' is not accurate) just thinks that you have intentionally enabled sentry and isn't going to fight you. I suspect it just checks when you drive into the home geofence and sets accordingly. If it doesn't work on next drive, then go checking the accuracy of 'home'.
Medved_77
Jan 20, 2020
1,999
1,973
Scotland
Thanks, so just to confirm, you have Sentry off at home and the app shows Sentry Mode not enabled?
I'll take the car out tomorrow, it's already plugged in and chucking it down.
Thanks for your help.
Jason71
2,682
2,457
Shropshire
Have you set your home location in the Cars Satnav? That is the "home" it refers to.
You did not actually mention that you have done that
Reactions: Durzel
Medved_77
Jan 20, 2020
1,999
1,973
Scotland
Yes, that's been done. Suspect I just need to leave the geofence and return. Will confirm later today.
Durzel
3,083
2,092
Bath, UK
I had the same problem. Address didn't exist on Google Maps, and until it did the car didn't know where it was either, so I couldn't stop Sentry from being on at home without disabling it entirely.
As said above, if this is a recent change and you haven't left and come back, then Sentry won't just suddenly turn off, you will need to leave the "Home" area and come back for it to realise you've entered the "Home" geofence.
Reactions: Medved_77
Medved_77
Jan 20, 2020
1,999
1,973
Scotland
Just to update with a resolution:
As @VanillaAir_UK suggested I needed to leave the geofenced 'home' area and return. Sentry mode now shows as off in the application when parked at home.
Car was still at home until about 11.30 so was online as sentry mode was active.
Short drive thereafter, car remained online between drives as was away from home and sentry active.
Car was online for a bit after returning home then went to sleep until just now when I woke it with the app.
Happy with that, should save me some consumption, just crossing my fingers that there's no ill effects on the ev.energy app now that the car isn't always online.
Reactions: Durzel
