I've been using a Samsung T5 SSD USB since the day I picked up my M3 month ago. I have it partitioned into two separate partitions, one with the TeslaCam folder, the other containing all my music. Seems to work flawlessly.
i keep getting an error message saying my USB drive is too slow to record from my M3’s camera. It’s USB 3 so should be f, but obviously isn’t. I’d be very grateful for recommendations as to a super-speedy drive I can use.
I’ve started to get this recently on occasion too. Most of the time it’s fine, but occasionally won’t record.
I have a super high speed (read & write) usb stick that is much faster than the recommended speed so I’m pretty convinced it’s not the drive.
Edit - usb drive is up to 400 MB/s read and 200 MB/s write.
Which usb drive is it and how did you measure the speed? Up to says nothing.. it's the continues write speed that is important and also if it can withstand high temperatures because it is in is continues.I’ve started to get this recently on occasion too. Most of the time it’s fine, but occasionally won’t record.
it’s this one.....
Patriot 512GB Supersonic Rage Elite USB 3.1 Type A, USB 3.0 Flash Drive With Transfer Speeds of Up To 400MB/sec https://www.amazon.co.uk/dp/B07NLL9SZ6/ref=cm_sw_r_cp_api_i_zmEaEbRNH7JVV
After speed the big problem is durability. Teslas do a lot of writes and this will wear out a USB, SSD or an SD card.
Assuming a conservative 1000 write cycles (most are MUCH more) and 8MB/sec write (double the current requirement), a 128GB drive should give well over a year of use before wearing out when used 8 hours a day (way more than most users, I suspect).
Believe it or not, but there are people that actually have Sentry Mode on 24x7, I'm not one of them by the way.....
But sentry mode records much much less than dash cam... and only when triggered ... so it's nothing like having dash cam recording 24hrs.
