Took me a while to decode: it's myco-remediation, not my-core-mediationMycoremediation? Anything useful for Icelandic weather?
https://cleantechnica.com/2020/03/08/the-sacred-rivers-climate-project-reducing-climate-impacts-with-mycoremediation
She meant to go out the other day, but it was raining. Not much more fencing to do, she said. (As in perimeter.)Hi @KarenRei. Do you plan to resume posts about posts (fence posts, that is)? I have quite enjoyed following your project and adventure, hope it is still on track, and that you are retaining an edge in the battle against the neighboring sheep.
Cheers.
The force of those river flood waters must be insane. The spot where the fence runs up next to the river (near the waterfall on the west / seaward side of the property) snapped three posts off at their bases. Friggin' nuts. Will redo it stronger, and possibly with some ways to allow the netting to "tear off" of the posts when under extreme force.
- I've strung net on all of the poles (5 heavy reels of the stuff!). Barbed wire is halfway across (not as heavy, but really awkward to carry!). Right now I'm finishing up the landslide zone (wearing rubber boots because it's so soggy ). I was short one reel of net and two reels of barbed wire, but the donations this winter / spring paid for it.
I'm sure you've already done your research on fencing, however you can save yourself some pain by building heavy posts above the floodline then hanging some tear off netting below.
This terribly formatted website has very handy information.
https://www.afence.com/BekaertBrochure.html
The picture below describes the general layout. However I would also add some stays on the downriver side of the posts to protect them should there be an exceptionally high flood, and because the fence is normally going across the fall of the hills which can lead to the fence leaning downhill over time as stock lean on it.
Some additions, I wouldn't use a frame on the bottom portion, just netting is fine as it will tear off in a flood and wash away anyway. Hanging corrugated iron (aligned so the corrugations are in line with the water flow) instead of netting is even better as it tends to lift up during a flood and float on the water - so it can survive floods better. That said, it looks quite ugly.
Also, choose the heaviest steel posts and cable you can find. Ideally it should then last a lifetime and you'll only need to replace the hanging portion from time to time - a much more pleasant job.
Good information on getting to Iceland this summer:
Iceland prepares to reopen to travelers. Here's how to get there on points this summer
Sounds very good.
Both net and barbed wire between all the poles?
You probably already know that tree "naturally protect each other against the wind".
united we stand, divided we fall
