Serice center switch and power supply upgrade?
Discussion in 'Model S: Battery & Charging' started by SabrToothSqrl, Jun 5, 2015.
  1. SabrToothSqrl
    SabrToothSqrl Active Member
    PA
    So, I emailed SC about my sunroof issue, and they told me I 'qualify' for a switch and power supply upgrade. (Free). So... They have to discharge the battery she says, going to take a few days. Ugh. I get a loaner, but still a hassle when SC is 90 minutes away...
    anyone know what's different about this switch? Run faster? Jump higher?
  2. pgiralt
    pgiralt Supporting Member
    Cary, NC
    This is a replacement of the main contactor in the battery. Basically a large relay that connects and disconnects the high voltage battery from the car. There have been reports of some contactors failing, leading to the being undriveable until it is fixed. This is a proactive replacement of the contactor so you don't get stranded and would suggest having the service done at your convenience.
    I had mine done in a day, so not sure what the multiple days is all about.
  3. NOLA_Mike
    NOLA_Mike Grouchy
    Hammond, LA
    If they need the battery discharged then bring it in very low on charge and that will give them a good headstart.
  4. gnelson
    gnelson Member
    Las Vegas, NV
    They want it to be at or below 30% charge. If you don't have the charge depleted they will need to discharge the battery.
  5. rlang59
    rlang59 Member
    US
    When I had mine done a few months back they asked to have it discharged to 50%.
    Also see this thread before this gets merged in anyway:
    Proactive Contactor Replacement
  6. caddieo
    caddieo Member
    Palm Coast, FL
    Thanks for the tip. I have mine scheduled for 7/15. Will have to inflict range anxiety on myself. :wink:
  7. SabrToothSqrl
    PA
    It's a 90 mile trip on the turnpike... I can easily arrive with 30% left...
  8. rlang59
    rlang59 Member
    US
    Why aren't they picking the car up?
  9. SabrToothSqrl
    PA
    They told me that costs me... is that not true?
  10. AmpedRealtor
    AmpedRealtor Well-Known Member
    Buckeye, AZ
    Valet service is now limited to a 10 mile radius from the service center, I believe.
