Serious 12v battery corrosion. Normal?
Discussion in 'Model Y: Battery & Charging' started by Fobia, Feb 11, 2021.
  1. jcanoe
    jcanoe Active Member
    Maryland
    #21 jcanoe, Feb 18, 2021
    You can make a paste of baking soda and water, apply the baking soda paste, scrub with an old toothbrush and let it sit for a short time, then flush with fresh water. You can also apply the paste to the battery cable clamp. Auto parts stores sell a battery post cleaning tool that can clean off a battery post and also includes a small wire brush to clean the inside of the battery cable clamp. Wear eye protection and rubber gloves as the battery acid residue is sulfuric acid based. Concentrated sulfuric acid is highly caustic to skin and clothing. The acid can be nuertalized by the chemical action of the baking soda and water. Repeat as necessary and flush clean with plenty of fresh water.
  2. MY-Y
    MY-Y Member
    MD
    Tesla should clean up that mess as part of the warranty repair.
  3. Pianewman
    Pianewman Member
    Fort Worth
    Fobia: Please tell us that your SC cleaned that area before installing the new battery?????
  4. Fobia
    Fobia Member
    Orlando, FL
    Nope. The guy cleaned the negative port a little, swapped the battery and left.
  5. alstoralset
    alstoralset Man from another place
    Pacific Northwest
    I would definitely send the photo to Tesla support and request it to be fixed, to at least make them aware of the issue (in case it damages something later).
  6. Pianewman
    Pianewman Member
    Fort Worth
    ^^^This. Did the tech know you took the photo of the tray? There's NO WAY the tech should have completed the job w/o properly cleaning the battery tray.
  7. jboy210
    jboy210 Supporting Member
    Northern California
    If the battery cage is plastic coated you can wipe it down and reinstall the battery. If it raw metal I would spray some paint on the metal before replacing the battery.
  8. Pilot1226
    Pilot1226 Member
    CRC makes a great battery cleaner and spray protectant. I’ve used it for years to help keep my batteries as healthy as they can be.
