Service Diagnostics Menu
Discussion in 'Roadster: Technical' started by suxxer, Jun 6, 2011.
  1. suxxer
    suxxer ElektroVolt
    Zurich, Switzerland
    Anyone knows what's hidden here? Couldn't find out the code so far...
  2. EV_de
    EV_de Model SP10/XP9 EU ZOE#47
    Germany, IN
  3. NigelM
    NigelM Recovering Member
    Northern Virginia
    #3 NigelM, Jun 6, 2011
    Could it be?
  4. EV_de
    Germany, IN
    #4 EV_de, Jun 6, 2011
  5. suxxer
    suxxer ElektroVolt
    Zurich, Switzerland
    TM isn't that nerdy ;)
    Anyone else got access?
  6. Slackjaw
    Slackjaw Member
    Central NJ
    #6 Slackjaw, Jun 8, 2011
    It's not likely to be 42 but only because it's too short.
    You're talking about a company whose CEO sent a wheel of cheese into space? Underestimate their nerdiness at your peril!
    P.S. At risk of being banned forever from the forum, my guess is 55378008, which is the "punchline" of an elaborate Dolly Parton joke told using a cheap calculator. Ahem.
  7. TEG
    TEG TMC Moderator
    710 707 would be more appropriate.
  8. Slackjaw
    Slackjaw Member
    Central NJ
    Ah, yes... I like it! :biggrin:
  9. NigelM
    Northern Virginia
    I refuse to tell what I did in my previous life but here's the logic to crack a code number:
    This type of pad suggests a 4-digit code.
    The "0" is almost never used (unless as an "enter" key at the end of a 5-digit code).
    The first number is more often than not one of the top two corners; 1 or 3. Using the roman alphabet most of us start as we would start writing, at the top left. So a better than 50% chance that 1 is the first digit.
    The second number is most likely one of the bottom two corners; 7 or 9. We like to think that we choose random patterns for these things but our mind tells us to create memorable patterns and again, there is a tendency to go left. Recommend trying 7 as the second digit.
    Now our need for randomness sends us back to the top, trying to get as far away as possible from the first two digits. Try 3 as the third digit.
    Finally, totally ignoring the chaotic process needed for a truly secure code number we realize that no number has been chosen from the center row or the center column so we choose 5 as the final digit.
    Try "1735" and send me a case of good Weissbier if it's correct... :biggrin:
  10. Lloyd
    Lloyd Well-Known Member
    San Luis Obispo, CA
    Try 8752 (TSLA)
  11. vfx
    vfx Well-Known Member
    CA CA
    I know!
    Elon's 1st kid's maiden name birthday!
  12. Slackjaw
    Slackjaw Member
    Central NJ
    Fascinating post Nigel and congratulations, you just guessed all my ATM PINs... But given the power of this screen and the tempting menus which must hide behind it, I bet it is car-specific. I would have appended the last 4 digits of the VIN (backwards/transposed?) or something. Imagine someone posting a root crack on a forum and hey presto, we're flashing our own firmware updates and everyone's driving a Roadster Sport++ which gets 10 miles/charge until someone finds the settings to explode the car or something... :crying:
  13. NigelM
    Northern Virginia
    But that's too simple (and I bet Suxxer tried it already) for the consequences you suggest, and has more chance of an owner hacking it out of curiosity. For our garage keypad entry I generated a truly random number with no obvious pattern and my wife hates it. After 2 years of use she still has a hard time remembering it, but it's just a 4-digit code.
    P.S. Suxxer never told us where he found that screen...
  14. dwegmull
    dwegmull 2013 Model S 85
    Redwood City, California
    On my car, I stumbled across it one day while waiting for a colleague to join me for our car pool: the car was off and it was going through the various menus, which lead me to wonder what technology of touch panel TMC is using. I started tapping on the "info" screen away from any button (the upper right corner or the space between the exit button and the left arrow will do). After 7 taps, the diagnostic menu appeared. Fearing I may mess up something, I backed out without trying any code.
    As a side note, I remember posting about this "feature" here, but now I can't find my post... I guess I'm just getting old!
  15. rsquared99
    rsquared99 Member
    Surprise AZ
  16. scott451
    scott451 KWH-PWR#1349Sprt,S Sig#96
    Palo Alto
    TM is that nerdy.
    The problem with publicly requesting/posting/providing the number, is that once it gets out to the general public, Tesla will just change the code. We've already seen this in the now partially encrypted log files and password protected shell access.
  17. suxxer
    suxxer ElektroVolt
    Zurich, Switzerland
    Yeah, just tap 4 or more time at a fast pace ... ;)
    Naaa....the Roadster doesn't wear glasses ;)
  18. NigelM
    Northern Virginia
    Asked my Service Ranger - the pass-codes are Ranger specific (I guess so they know for the access logs). Behind the PIN screen there are various options for resetting the PEM and turning certain systems on and off during service work and to stop the Rangers electrocuting themselves. There are also more detailed (technical) diagnostics messages.....
    Thought you might like to know.
  19. donauker
    donauker Member
    Wow, nice line. Wonder how they do the updates?
  20. S-2000 Roadster
    With a computer and a cable!
