Servicing the Tesla in Oz
Discussion in 'Australia' started by brewster, Apr 18, 2015.
  1. brewster
    brewster Member
    Warrnambool. Vic. Australia
    Did a search without luck. Can anyone with a Tesla help please?
    What are the servicing arrangements cor the Model S here in Oz?
  2. lennier
    lennier Member
    Melbourne, Victoria, Australia
    For Victoria, Richmond service centre before the end of the month with any luck.
  3. brewster
    brewster Member
    Is there a standard cost and how often?
  4. doctorwho
    doctorwho Active Member
    Eurobin, Victoria. Australia
    There's no routine service regime that I'm aware of, certainly no service requirement for warranty cover
  5. Dborn
    Dborn Confirmed
    Sydney, Australia
    No one has discussed servicing with me. essentially, if you have an issue, you go in and get it sorted at the service centre (in Sydney, anyway). If they pick up an issue remotely, they will contact you to make arrangements to get it sorted.
  6. meloccom
    meloccom Moderator Aus/NZ
    Sydney Australia
    #6 meloccom, Apr 19, 2015
    In the owners manual it states:
    "Service Intervals
    Regular maintenance is the key to ensuring the continued reliability and efficiency of your Model S.
    Rotate the tires every 5000 miles (8000 km) (except on Performance Plus models), maintain the correct tire pressures, and take Model S to Tesla at the regularly scheduled maintenance intervals of every 12 months, or every 12,500 miles (20,000 km), whichever comes first. It is also important to perform the daily and monthly checks described below.
    Model S must be serviced by Tesla-certified technicians. Damages or failures caused by maintenance or repairs performed by non- Tesla certified technicians are not covered by the warranty.
    I intend to bring it in once a year as I am unlikely to do 20,000 Km a year. The price for a regular service in the USA is $600 plus you can buy packages but these have not yet been announced in Australia. There is a Service Centre in Sydney with one being built in Melbourne as we speak. If you live a long way from a service centre they have The Ranger service but that's at extra cost.
  7. raynewman
    raynewman Active Member
    Brisbane, Australia
    and if you have a problem in Brisbane, they fly someone up.
  8. Keiron
    Keiron Member
    Melbourne,australia
    Nope no routine service as such. The scarry part is I am over due for my Tyre rotation of 8000Kms- very nearly 10,000Kms-Racking up them k's and lovin it!.
  9. Keiron
    Keiron Member
    Melbourne,australia
    Hi Guys,
    Interesting additional data from Nathan at Tesla Melb Service Centre regarding tyre rotations.
    You need to check that your car/build has symetrical tyre ie. mine has 245 R 21 all round. Therefore is theoretically rotatable BUT..... Each rim has a locational RFID sensor on it the tell the car where the wheel is in the traction/brake array. If one goes of the K Mart tyre and Auto or someone like that they will dutifully rotate but bugger up your setup and the the drive system goes into panic thereafter. The Cars MPU has to be reset to reallocate rim to position data including tyre pressure data.
    In my own case, to prevent this trauma, Ive booked my car ( approx 9000+ Kms already ) in with Tesla Richmond in 3-4 weeks( their guesstmate opening date ) to inspect tyres rotate and check balance in one action.
  10. marchino
    marchino Member
    Perth, Western Australia
    Why Rotate Tyres?
    Why do we need to rotate tyres? I thought that kind of thing went out with crossplys.
  11. Mark E
    Mark E Member
    Sydney NSW
    Not if you want optimal life from the tyres. On my other cars I have different size front to rear and directional tyres. You rotate them sized to side and have the tyres reversed on the rims...
  12. Davide
    Davide Member
    Melbourne
    Tesla Richmond? YiPPY!
  13. marchino
    marchino Member
    I suppose I must drive differently, as my tyres wear pretty evenly on left and right. Front and rear wear differently, of course, so I just get a pair replaced when they wear out. The only time I have rotated tyres is when I bought one separately as a result of a puncture - I moved it around to try to even up the wear with the other tyres.
    I'm a bit confused about the directional tyres - my unidirectional tyres have to be fitted on the rim in one particular direction - so I can't reverse them on the rim.
  14. Mark E
    Mark E Member
    Sydney NSW
    The tyres on performance cars often wear the inside edges because of the camber in the suspension.
    Directional tyres have an arrow indicating the rotation and so they must be reversed on the rim if you swap left to right or vice versa.
  15. oystero
    oystero Member
    Melbourne
    Thanks Keiron. I have rotated my wheels myself 2 weeks ago. No warning yet :) fingers crossed. I must have been lucky with the positioning when mounting the wheels back
  16. Keiron
    Keiron Member
    Melbourne,australia
    Gudday Oystero,
    Interesting..... Nathan at Tesla was saying the effect of 'Wheel confusion' is instant..... I will call him back.
  17. brewster
    brewster Member
    Hi Oystero. Curious to know what procedure and equipment you used when rotating your tyres.
    Or anyone else who hase done the tyre rotation on their Model S.
    • Are they the standard 19" or?
    • Did you rotate front to back for each side or cross-over front to back or?
    • Did you raise one side of the car to swap or completely raised or?
    • What capacity Trolley Jack and Jack Stands or?
    • Any other relevant info?
  18. Dborn
    Dborn Confirmed
    Sydney, Australia
    I use a 1300 kg trolley Jack. No sweat. I also use a 20 mm load spreading piece of wood with it. Actually a modified parquetry block. Otherwise I feel the circular steel bearing plate might damage the car.
