Set Up WiFi Popup
iffatall
695
240
SF Bay Area, CA
For the last few days, every morning, when I get into the car to go to work, I see this pop up message to setup a WiFi connection as the screen comes on. Why this is odd is that the car is already connected to my home WiFi at this time, as you can see in the pic. I am a little confused about this. Has anyone else experienced this issue?
(Sorry for the terrible photo.)
AnOutsider
S532 # XS27
Apr 3, 2009
11,957
198
Do you have multiple networks near you? I notice that if I come back to the car and it has been in range of a network it doesn't know about, it nags me. Seriously annoying though. If there's at least ONE network setup, then clearly I know that I can do it on others. Go. Away.
iffatall
695
240
SF Bay Area, CA
...Try a reboot.
Thanks, that solved the issue.
- - - Updated - - -
like a nanny screen.
gets pretty annoying especially when you don't have wifi that works where the car is
Actually, the issue I posted was that I did have WiFi, and was connected to the network. If you look closely, the WiFi icon is there on the top. I even double checked internet access. That is why I found it odd that it was asking me to join a network even though I was already connected to a network.
Todd Burch
Voltage makes me tingle.
Nov 3, 2009
7,801
28,498
Smithfield, VA
You could also have tried tapping the "Connect To Wi-Fi" button instead. Tapping "Not Now" is the very thing that probably schedules that popup to appear at a later time.
iffatall
695
240
SF Bay Area, CA
I did try that too. When I tap on "Connect to WiFi", it lists the WiFi networks around, so I can tap on one to connect. The list included my own network, with tapping disabled on it with a label saying "connected" or something like that. Obviously I didn't want to tap on another network. So essentially, "Not Now", and "Connect To WiFi" effectively resulted in the same outcome. The popup appeared next morning again.
As I said, a reboot seems to have fixed the issue, although there is no way to be certain.
cinergi
2,176
40
MA
I get this all the time now (and I'm *connected* to wifi). It didn't happen until a recent update (it was a bug before, seemed to have been fixed, and it's back again).
jive_devil
157
13
SoCal
It's a bug.
I had the same issue, and after I tried all the tricks you guys attempted, I called the service line. They ID'd it as an incorrect flag in my profile. They dialed into the car, wiped the flag, and I haven't had a problem since (and it's been a few weeks now).
DriverOne
854
509
Austin, TX
Same here. Reboot didn't fix it. Service center was little help - I think there may have been a communication error between them and CA.
Anyway, I deleted my home wifi then re-added it. So far so good.
Lump
2,617
2,399
So. Cal.
I've had the pop up for months & it annoyed the hell out of me, a couple days ago I removed my home network & re-added it...thanks for the tip.
