Setec CCS to Tesla Adapter
Discussion in 'Supercharging & Charging Infrastructure' started by Boeingpilot, Dec 29, 2020.
  1. Forty_Too
    Forty_Too Member
    Chicago, IL
    Yes, I’ve installed the driver. Makes no difference, still doesn’t show up.
  2. C0ran
    C0ran Member
    Seoul, South Korea
    How about change USB cable?
    Some micro 5pin cable does not support data connection. (just charging)
  3. Hydrocarbon302
    Andrews TX
    Got my adapter yesterday and updated the firmware. I had to try a few different cables to get the computer to recognize the adapter but eventually the computer made the usb connection sound. It updated successfully however Norton kept removing the update file so I had to un-quarantine it,
    Hope to test the adapter today.
  4. Cosmacelf
    Cosmacelf Well-Known Member
    San Diego
    Don’t you love dodgy upgrade files from Asia that couldn’t possibly be infected with malware? :eek:
    • Funny x 3
    • Disagree x 1
  5. Hydrocarbon302
    Andrews TX
    My laptop is not the property of the CCP...
  6. tstolze
    tstolze Member
    OFallon, MO
    It is now. ;) lol
    • Funny x 7
  7. Forty_Too
    Forty_Too Member
    Chicago, IL
    Figured it out - I had tried about 6 different cables and verified that they support data. However, you really have to shove it in there, at least with the cables I had. If you just plug it in like you would any other device, the green light lights up and it appears to be getting power, but, it didn't connect to the computer until I pressed it in hard and held it there for the duration of the firmware update.
    Anyway, firmware is updated now... sadly I took a trip to the Supercharger yesterday so my battery is "full", but I'll try again soon.
  8. Reddy_KW
    Reddy_KW Member
    Gulfport, MS
    I got hold of support last night for a firmware patch from a log file I sent them. I was trying to get the adapter to work with a 50KW Efacec charger here at my workplace since charging is on the house. No luck after the first firmware patch. I’ll see what happens after the next iteration.
    I also went to my local EA station to do some more testing with the v126-1 that got pushed out. The 150 kw signet charger peaked at 48kw. I tried the 350 kw signet dispenser just for the heck of it. It works on the 350 kw unit but i got some pretty wild ramps. The power output kept bouncing up and down between 33 -76 kw. I was afraid of damaging my battery so I stopped it immediately. See attached picture. The charger rate number is blurry because it was changing so rapidly. 2DCB9B60-1C5D-49E4-A481-587F16C911C2.jpeg
    • Informative x 3
  9. Hydrocarbon302
    Andrews TX
    haha my phone changed now to not.. I suppose my phone is being rebellious?
    • Funny x 3
  10. Hydrocarbon302
    Andrews TX
    Just checked Setec website before I left to test at EA. Already another update V128.
  11. mrc3
    mrc3 Member
    Minnesota USA
    Not sure what car you have, but if the Model 3/Y likely you will not be able to exceed 50KW with ANY adapter (only >50KW with supercharger) See earlier comments from Randy, the car limits to 126A.
    Mike
  12. Hydrocarbon302
    Andrews TX
    Attempted to charge at the Midland Electrify America station with my 2020 MYP 2020.48.30
    Tried all four stalls and got a vehicle timeout error on the stall and a “charger not powered” message on the car.
    I used the EA app, swipe to pay. Tried to prepay and pay after connecting.
    I used the adapter to ccs and adapter to car and power on adapter connection method.
    Adapter has v128 firmware installed.
    The chargers are 150 & 350 ABB units.
    I called EA tech support and the nice lady reset the charger. Same results.
    0C40F425-AA1E-4CF9-9C57-DA8038270FF6.jpeg 758BAEE5-A740-40BB-96FB-0F2A34C04FA2.jpeg 9D54B98A-9B23-49F5-A59A-BD1D4E9DB32F.jpeg 890FBDE5-5216-479E-B51A-8E22984C1A41.jpeg
    • Informative x 6
  13. C0ran
    C0ran Member
    Seoul, South Korea
  14. Forty_Too
    Forty_Too Member
    Chicago, IL
    No dice for me on 128 on EA and EVGo :(
  15. DMC-Orangeville
    DMC-Orangeville 85D and John Deere 5100E
    NW of the 6ix Canada
    Flo is now in the USA. They have done a bunch of Level 2 "street lighting" applications in LA. Flo has hired reps in key states recently, and has launched their 50/100 KW DC chargers - so you may see them soon.
    I Know the California Rep personally, PM me if you want their co-ordinates.
  16. cwerdna
    cwerdna Active Member
    SF Bay Area, CA
    If PlugShare - Find Electric Vehicle Charging Locations Near You (200 W. I-20, Midland, Texas, 79701, US at a Walmart) was the location, I see mixed reports there.
  17. Hydrocarbon302
    Andrews TX
    Yep that’s the only DCFC close to me besides the Tesla SC. All four dispensers behaved exactly the same, more or less, which leads me to believe the issue is the adapter. Could be wrong though.
  18. Randy Sinn
    Randy Sinn Member
    Seoul, Korea
    Thanks for your kind words.
    I am sorry I don't understand what "how does point 3 interact with charging speed that needs to taper down when higher SOC?" means?
    Can you tell me in a little easy way?
  19. chinney
    chinney Member
    Ottawa ON
    Clearly, this adapter is still very much in beta testing mode.
  20. ItsNotAboutTheMoney
    ItsNotAboutTheMoney Well-Known Member
    Maine
    Your "point 3" was:
    "3. Model 3's limit can be lifted by FW update, but actually it is not lifted but "forced". So forced current could disrupt the system.
    I have tested about 8 months with the curreent-forcing FW, but I had no problem. However, if you want to use the current-forcing FW, it should be totally on your risk. (I'll share it here if it is permitted.)"
    The car has a maximum charging amperage limit that depends on the state of charge, battery temperature etc.
    I think they were asking whether forcing a higher amperage would exceed that amperage limit. They might be worried about damaging the battery.
