Setting up a free AWS cloud server for VisibleTesla etc
Discussion in 'Wiki' started by Wiki, Feb 24, 2016.
Tags:
Thread Status:
The first post in this thread is a WikiPost, and can be edited by anyone with the appropriate permissions.
  1. Wiki
    Wiki Member
    Amazon AWS offer Free Cloud services for 12 months when you sign up for a new account.
    You get use of their smallest "instance" which is more than powerful enough to run VisibleTesla, so on request I've drafted a small HOWTO that will help you get started.
    After the free period runs out it will cost up to US$20 per month so set yourself a calendar reminder to avoid bill shock!
    This is only a rough draft for now, any assistance cleaning it up is appreciated
    Before starting, create yourself an amazon AWS account
    I won't repeat the already excellent documentation available here
    Step 1 - change region
    - new virtual servers are created in one of Amazon's datacentres
    across the globe.
    - the default is "US West", for more responsive interaction with your
    new server I suggest changing this to your closest region.
    - in my case, Sydney is the closest.
    Step 2 - create new EC2 instance
    - click "EC2"
    - click "Launch Instance"
    - select "Ubuntu Server 14.04 LTS (HVM) SSD Volume (64-bit)
    - make sure the "Free tier eligible" top tier is selected
    - click "Next: Configure Instance Details"
    - change "Auto-assign Public IP" to "Enable"
    this will allow you to access your new VM directly
    - click "Next: Add Storage"
    - increase the Root volume size to 30 GiB
    - click "Next: Tag Instance"
    - click "Next: Configure Security Group"
    - Add a rule for TCP port 5901 (VNC) so you can manage VisibleTesla
    - Make sure the SSH rule (port 22) is there as well.
    - if you have a static IP at home, choose "My IP" for extra security
    - click "Review and Launch"
    - click "Launch"
    - you will be asked to use or create a new key pair, this is used for accessing your server's command line. If unsure, select "create a new key pair". Put in your name as the key pair name.
    - click "Download Key Pair" and store this in a safe location
    - then click "Launch Instances"
    - click "View Instances" and wait until "Instance State" is "running"
    and has passed the "status checks"
    Step 3 - Connect via ssh to your new EC2 VM to install Java7 and VisibleTesla
    Install Putty and load your private key using these handy instructions from Amazon AWS
    Use Putty to connect to the "Public IP" of your AWS instance and log in with username "ubuntu"
    set your timezone with the following command
    Code:
    sudo dpkg-reconfigure tzdata
    install Oracle Java 7
    Code:
    sudo add-apt-repository ppa:webupd8team/java
    sudo apt-get update
    sudo apt-get install oracle-java7-installer
    install vncserver and some other useful tools
    Code:
    sudo apt-get install vnc4server xfdesktop4 xfce4-session unzip nano vim screen fonts-freefont-ttf libxslt1.1
    download and unzip the latest beta version of VisibleTesla (0.50.xx)
    Code:
    wget https://dl.dropboxusercontent.com/u/7045813/VT2/RawApp/VisibleTesla.zip
    unzip VisibleTesla.zip
    configure vncserver to start VT automatically
    Code:
    mkdir .vnc
    nano .vnc/xstartup
    then type these two lines into the nano window:
    Code:
    xsetroot -solid black
    java -jar "/home/ubuntu/VisibleTesla 0.50.08/VisibleTesla.jar"
    press "Control-X" then "Y" for Yes, and press "Enter" for the file name
    change permissions on the xstartup file
    Code:
    chmod 700 .vnc/xstartup
    now run vncserver
    Code:
    vnc4server -geometry 640x460
    it will ask for a password.
    this is the password for accessing your VNC (VisibleTesla)
    this is not the same as your "My Tesla" password but should be a secure password
    because anyone that can guess this password has full access to VT
    and to your amazon instance, and therefore can potentially cost you a large amount of money
    If you want to reset your VNC password, type:
    Code:
    rm ./vnc/passwd
    you can now close the PuTTY window, as from here on you can configure VT via VNC
    Code:
    exit
    Load up your VNC client, put in your public ip and port (eg 52.1.2.3:5901), and connect. After typing in the VNC password you set above, you should see the VT login screen. Enter the email address and password you use for accessing "My Tesla", and click "Log In"
    VT documentation is available here
    add your email address to the "Email for notifications" section (click the "Prefs" tab)
    then under the "Notify" tab in the "Charging" section I suggest setting some custom Message options (click the + next to each of the options)
    eg under "SOC" Hits or Exceeded I have:
  2. AZ Desert Driver
    AZ Desert Driver Rare combination
    Tucson AZ
    What IS visible tesla? Why would I want to do this joining dance?
  3. csshih
    csshih whirrrr
    San Jose, CA
    VisibleTesla
  4. ggenge
    ggenge Member
    Calgary, Alberta, Canada
    I want to track my Tesla Trips - is Amazon the only way to run Visible Tesla so that it collects data all the time?? How could we do this for a bulk of users? Could we share an Amazon Server? offer it as a Service?
Thread Status:
