Setup wizard password changed?
cwied
887
637
San Mateo, CA
Has anyone noticed a setup wizard password change after getting 1.17.2? If not, I suspect Tesla changed the password on my gateway after I unwisely mentioned I was using the wizard to get around the 1 hour time lag on app settings. I recommend not making the same mistake.
Reactions: NuShrike
BJReplay
87
60
St Kilda West
I had a user do some debugging for me on 1.17.1 - he noted the login would only work 10% of the time. The solution we've run with is to change force_sm_off to true rather than false.
Reactions: cwied
Icepicknz
47
6
Auckland new zealand
passing the true for force_sm_off seems to have fixed it for me too; however i'm having some other weird issues where the power wall won't charge from the grid when i put it in backup mode ;( its a new power wall so have a fault logged with tesla
cwied
887
637
San Mateo, CA
Apparently the note that the wizard won't launch when the system is off-grid or a firmware update is in progress needs to be expanded to add that it also won't run when the system is charging or discharging.
miimura
6,478
6,228
Los Altos, CA
That sounds pretty ridiculous. If you're in self-consumption mode, that should be most of the time.
