Hi everyone,
So I have a few Martian Wheels questions (Also Vossen as an after thought to make things more confusing lol). I thought I had it all figured out and was about to make the switch. But several things have come up so I need to really make sure.
Background:
I'm getting my White LR Model Y w/ 19" Gemini's in about 2 weeks or so. I wanted to switch to the Martians right away. Either the 19x8.5's or the 20x9.5's. I'm someone who prefers function over form, but if I can find a happy medium I'd like form if the function is not too severely affected. Hence range is really imp for me but I don't mind if the range goes down a slight bit if I am getting more comfort and a cooler looking blacked out wheel.
1) I was told that the Martians are phenomenally stronger than the OEM wheels. So that will take care of any risk of wheel damage and longevity issues. Is this true?
2) I was also told that the 19x8.5 and even the 20x9.5 are far lighter than the stock Gemini's. So that will make for a much smoother ride, increased acceleration and similar range since they're lighter wheels. Is this true?
I know the Gemini's with the cover have some amazing range because of the aerodynamic efficiency. But if I took the covers off for an apples to apples comparison, the Martian's would be better than the Gemini's in terms of range right?
And even the 20" Martians would be pretty close to the 19 Gemini's in terms of range etc right?
(I know that range has a lot to do with the tires so please assume that I will be using the same stock Tesla continentals for the 19 or some other efficient tire I did the 20's.)
3) Someone who works in a garage told me that if I get the 8.5's instead of the 9.5's it might mess up the balance, torque etc of the car since the factory sets it up for 9.5 Geminis or even 9.5 inductions. Is that true? Would I have any issues going with a 8.5 instead of the 9.5's? Either in the 19 or 20's? Or is this a non issue?
4) Lastly just to confuse things more lol, any thoughts on the Vossen's (HF-3's) vs the Martians? Are they as strong? As light? And will they give me more or less the same performance as the MW03's?
Thank you so much for your time. I know there are tire threads out there. But I didn't find one that addresses all the questions that I have. So that is why I started this thread. Thank you in advance for all your help.
Regards,
Benjamin.
Tesla Model Y 19
Introducing the Vossen HF-3 Wheel
Background:
Regards,
Benjamin.
Tesla Model Y 19
