Several stops
Sumitava
New Member
Aug 16, 2020
3
0
Yorktown
Hello,
I do a job where I make 8-12 stops in a day for 30 -90 minutes per stop depending upon the need. The total distance driven is around 50-100 miles per day. I was wondering if a model 3 with single charge go that long?
Thanks!
jjrandorin
Nov 28, 2018
10,854
12,580
Riverside Co. CA
Hello,
Thanks!
If you get a LR one and not a SR or SR+ you should be fine.
RayK
2,222
2,222
San Jose, CA
Standard Range is rated at 220 miles. Standard Range Plus is 250 miles. Long Range is around 320 miles. I believe that's from 100%, down to around 5%. Assumes a mix of city/highway driving and would be a best case condition (YMMV). You would probably get better mileage in the city (stop-and-go driving) as that involves regen more than constant driving at highway speeds. Of course if you do jackrabbit starts all the time, then your range will suffer.
ref: Tesla Model 3 - Wikipedia (if you trust Wiki to give you the correct info)
