Share Google maps location to model 3 not working from android
Discussion in 'Model 3: User Interface' started by Swordtail, Mar 2, 2021 at 9:15 AM.
  1. Swordtail
    Swordtail Member
    UK
    This feature seems to have stopped working. It has only worked on a couple of occasions. I can wake the car, sit in it and do the "share". The tesla app says the destination has been shared with the car but nothing happens. The car doesn't route to the location nor does the location appear in the history on the car.
    Does anyone know of a workaround for this? I can't find anything of use in previous threads. I can't see any phone permissions that would stop this working.
    It's a 2021 UK model 3.
    Cheers.
  2. GtiMart
    GtiMart Member
    Quebec City, Canada
    I believe it works if you're not yet in the car when you share. I'm pretty sure I've had the same issue as you when I tried it while being in the car.
  3. Flatbat
    Flatbat Member
    Melbourne
    Try troubleshooting step no 1. Reboot the phone.
    I just checked in my Pixel 5 and whilst it had been working fine for me in the past it was not working just now. Tesla app said location sent to car etc. But like you rpeorted, nothing appeared in the car. Rebooted phon and all working fine again. Can share location from inside or outside of the car and works fine either way.
    My minor bugbear with the Share Location process in Google Maps / Android is that I cannot re-organise the list off apps to share to, so that Tesla is at the start. I have to scroll to the right through a list of ten other apps I never share locations to, to find the Telsa app. Which is would recall recently shared to apps and place them at the start of the list.
  4. Swordtail
    Swordtail Member
    UK
    Interesting. I have my phone set to restart overnight and it just worked now. I went and sat in the car to test it. It appears to depend on the location you are sharing. I tried cities, a couple of house addresses and things like shopping parks. If it "liked" a specific destination it would route to it every time I shared it. If it didn't route to it, it never would regardless of how many times I shared it. It doesn't seem to matter on the type of place, but the car clearly has specific requirements as to what you can share to it. Very odd. You'd think google maps would just be sharing coordinates and the car would route to the coordinates regardless of where exactly that might be.
    I agree about the Tesla app in the "share to list". You'd think Android would order the list by the app you share to the most. And the tesla app is the only one I'd ever share a location to.
  5. GtiMart
    GtiMart Member
    Quebec City, Canada
    That is interesting @Swordtail . I've seen the car's map take pretty bad routes to certain locations, or have bad locations for some shops. It does not have a "perfect match" of the Google Maps database for sure. Even if the latlong coordinate is shared, if the car doesn't find any "asset" match for it and cannot route to it, it might ignore it?
  6. Swordtail
    Swordtail Member
    UK
    Interesting again! I've done some more tests. There was a street address I "shared" which is ignored by the car, yet it will route to it if you input it directly :confused: If you share a house very close by on the same street, the car does route to it! Very strange. I have discovered that if you press and hold on google maps such that you get coordinates rather than an address as the location, it seems to work every time, even if the location is in the middle of nowhere. I think my workaround is to just press and hold in the middle of the road next to my location before sharing. That seems to work every time, so far!
    • Informative x 2
