ucmndd
Yes.Out of curiosity, what would be the type of outlet to install for 20A 240V? Is it the NEMA 6-20?
Yes.
You’ve got the gist of it.Thanks, so in addition to the 6-20 outlet I need a double pole 20A circuit breaker for the 240V.. Its odd though, I look at my other breakers and they all say 120/240V.. But I think its just that on the US grid one line is only 120V so you need two to get the 240V
Out of curiosity, what would be the type of outlet to install for 20A 240V? Is it the NEMA 6-20? I could easily install a 20A breaker and attach it to the wire in my existing box temporarily, and if needed in the future do a sub pannel.
While I do think cars should use less in the future, I am not anticipating it anytime in the near future unfortunatelySeems like they are only going up in battery pack size not down.
Model 3 ~ 220 watts per mile
Model Y ~ 250 watts per mile
Model S ~ 280 watts per mile
Model X ~ 300 watts per mile
Roadster ~ ????
CyberTruck ~ ???? ~ 400 watts per mile
Semi ~ 1000 watts per mile
Future RV Camper ..
I'm not sure that's actually true as they add diversity of platforms to the Tesla Fleet, but your point is valid.
fixed it.
Is the romex wire Orange? If so it should be 10 gauge and you could get a few more amps. My eyes can't quite see. I think 10 gauge romex would pair to a 30 amp breaker and you would get 24 amps continuous or about 22mph.
Darn, looks like they only installed 12 gauge wireWell looks like I am running a whole new wire.. not a huge deal, probably better anyways as I wanted the charger on the front of the garage not the back since Tesla's charge ports are in the rear of the car.
Nah, that is 10 gauge. 30 amps.
Thanks, I am glad that was pointed out, I can deal with 30A charging, the 14-30 plug type should deliver about 22mph which is more then enough I feel for my driving.
Very slightly off topic. Can the Tesla display be configured to read miles per KWH like the leaf?
Tanks.
The k in kWh is not kilometers. It’s kilowatts.
You can run Tesla in Metric or English units.
Range is in miles or kilometers (or battery percent full)
Speed is in mph or kph
Efficiency is watthours per mile or watthours per kilometer
Charging and battery capacity is in kWh (kilowatt hours)
Energy is in kW kilowatts
I’m probably not explaining myself well. Sorry. In the leaf one can look at (in metric fur example) 6.2 km per 1 kWh of power (or 4 ish miles per KWh of power). I’m asking if there is a way to see average kilometers per kWh in the Tesla.
Thank you.
Thank you.
I had updated my reply before you quoted me. But no, Tesla does not display efficiency that way. I hate distance per 1 kWh. Energy used per distance makes more sense. But it’s what ever you’ve been raised on. You’ll get used to it.
And so you are getting this backward, like I have seen many people do before. Larger and larger battery sizes lead to lower necessary charging speeds over time, rather than higher. You are defaulting to the idea of: "I need to fill [FULLBATTERYAMOUNT] overnight, so I need XXX amount of charging power." But that's not how that works. You drive XXX distance to work every day. As cars continue to improve in technology and range, that does not equal you living farther and farther and farther away from work. So you drive the amount you drive independent of the car's capabilities. And if the cars get to 400 and 500 and 600 miles of range, that just equals more and more leftover that you still have every night when you get home that doesn't need to be refilled and is really alleviating the need for much faster charging to have enough for tomorrow's driving.While I do think cars should use less in the future, I am not anticipating it anytime in the near future unfortunatelySeems like they are only going up in battery pack size not down.
