Shifts to Park when Butt Lifted from Seat?
Discussion in 'Model S: Driving Dynamics' started by mknox, Nov 26, 2012.
  1. mibaro2
    mibaro2 Member
    Georgetown, ON
    Here's my limited experience when I testdrove the Performance S yesterday, I tried to duplicate this problem, and I couldn't get the car to shift itself into park on its own when I was reversing into a parking spot. (The Tesla rep must have wondered if I always park lifting my butt in the air.). I was backing up very slowly, and had no problems.
    Michael
  2. byt
    byt Member
    Redwood City, CA
    It appears my ass leaves the seat automatically when I reverse in a car, a habit I must have developed over time and never noticed. The car doesn't just pop into park when I lift my but, it also has to be traveling under 2 MPH and my foot is off the accelerator. Seat belt is typically off as I am doing this but will try keeping the belt on as well to see if I can replicate the action.
  3. goaliemanshark
    Just tried it. Buckle up! Problem solved
  4. brianman
    brianman Burrito Founder
    I can confirm that it still happens in v4.0 and that the seatbelt solution worked fine. My speed was roughly 5mph in a parking lot and it was very uncomfortable in a whiplashy kind of way.
  5. NigelM
    NigelM Recovering Member
    Sarasota, FL
    I tried really hard to replicate this problem without success both before and after v4.0. I'm happy that it doesn't happen to me, but I'm actually wondering if you're all levitating?
  6. mknox
    mknox Well-Known Member
    Toronto, ON
    Is "Park" in a Model S the same as with an automatic transmission ICE (i.e. done in the transmission) or is it more akin to "Neutral with Parking Brake Applied"?
  7. jerry33
    Texas
    Park applies a second set of pads to the brakes. There is nothing like a parking pawl.
  8. doug
    doug Administrator / Head Moderator
    Stanford, California
    You sure? The Roadster has some sort of parking pin in the transaxel, as well as a cable hand brake.
  9. jerry33
    Texas
    Everything I've read says it's just an extra set of pads. Perhaps someone can confirm. It's not like I've taken the drivetrain apart or have a service manual.
  10. jomo25
    jomo25 P4398
    Tempe, AZ
    Did you unfasten your seatbelt?
  11. NigelM
    Sarasota, FL
    Yup..
  12. Doug_G
    Doug_G Lead Moderator
    Ottawa, Canada
    He is right. If you look at the rear wheels on the Model S there are two sets of calipers per wheel. The smaller second set is electrically actuated, and that's the parking brake. There's no pawl in the Model S drive train.
  13. doug
    I was aware of the electric parking brake, but that didn't give me any indication of the presence or absence of a parking pawl. There a reference somewhere?
    At any rate, if the car makes a sudden stop, you certainly hope it's from friction on a disk and not from a pin in the transmission.
  14. jerry33
    Texas
    Often, cars with parking pawls have a break-away clutch that prevents drivetrain damage--even though the parking pawl isn't supposed to activate at speeds 10 km/h or higher. Does the Roadster have one of those? If it does, then we can rule out the Model S having a parking pawl.
  15. tdelta1000
    tdelta1000 Active Member
    South Florida
    #75 tdelta1000, Dec 12, 2012
    This very problem was encountered in the carscom youtube "2012 Tesla Model S Charging" video.
    I propose that Tesla wire in a second seat sensor in the backrest portion of the seat to avoid the issue that was experienced in the video that mknox saw. I think it will be a quick and safe method in eliminating this problem.
  16. Doug_G
    Ottawa, Canada
    According to what I was told at the Fremont event, they're using the electric parking brake instead of the pawl.
  17. doug
    Back on topic, it sounds like you have to latch the seatbelt if you want to ghost ride Oakland style. Or would that not work?
  18. Brian H
    Brian H Banned
    OK, so leaving the seatbelt on prevents it, and so should a backrest (or seat under-railing) weight sensor. Short of levitation, as suggested, your weight must be supported by some combo of foot on floor and hand pressing down.
  19. jerry33
    Texas
    Perhaps I've missed something, but why would you unbuckle your seatbelt to back up?
  20. byt
    byt Member
    Redwood City, CA
    I always unbuckled to lift up off my seat while backing up (I'm short) to see objects behind me. I can't trust the backup camera and its useless when it rains!!
