shore power for precooling when charging is scheduled?
Discussion in 'Model S: Driving Dynamics' started by Crispix, Aug 30, 2013.
  1. Crispix
    Crispix Member
    San Diego
    Perhaps a dumb question: Does the car still use shore power to precondition the car when plugged in and climate control turns on, even if I have a scheduled charge time?
  2. efusco
    efusco Moderator - Model S & X forums
    Nixa, Missouri, United States
    Yes. Even if you just open the door, it begins drawing shore power with scheduled charging.
  3. FlasherZ
    Mine only does it if the climate control is on when I open the door. If the climate control is off, opening the door doesn't turn on the EVSE.
  4. mknox
    mknox Well-Known Member
    Toronto, ON
    One thing I've wondered about (and should probably test) is what happens if you're charging at a reduced rate, the charging is under way, and you open a door activating the a/c or heat. Does the car "respect" the charge limit you've set, or does it add the HVAC load on top of the charging load (if both are still below the adapter's rating)?
  5. jerry33
    Texas
    It respects the charge limit you've set. I have mine set to 32 amps rather than 40, and it doesn't go above that. When pre-cooling, I can see the mph is slightly lower.
  6. strider
    strider Active Member
    NE Oklahoma
    Yep, Jerry is correct. I have seen the same behavior.
