I thought this data might be interesting to some on the forums.
I was on vacation for over a week and so my M3 sat in my driveway unused. I normally charge to 80%, but I had set it to only maintain 50% while gone. Yesterday on my flight home I set it back to 80%, so yesterday afternoon it charged back to 80% (but I did not use it at all that day).
This morning I fired up my cabin heating before leaving the house resulting in the following power draw: (I do not remember if it showed any icon in the app to indicate if battery heating was happening) . This graph is from my Sense Energy Monitor (shows whole house draw - yellow is solar production so ignore that)
I have a 60a circuit (48a continuous) into my Wall Connector. I have a M3 LR. The car was fully cold soaked this AM after over a week of not being touched. The app said it was 31f in the cabin when I told it to warm up (frosty morning).
Note that my gas furnace I think was running at the start of this graph (about 1000 watts) and I suspect it stopped during the car charging interval.
I got the "regen limited" warning when I fired up the car and the dots that show the reduction. I drove my 15 miles to work and I think I still had more dots than usual (they eventually all go away right?). Regen worked to some degree though (it was not as noticeable as charging to 100% where you get no regen - though maybe that was because it did pre-heat the battery a bit)
I think the interesting bits here are that it seems to nearly max my charger (11.5kw) just doing warmup (presumably none of this was going to battery charging). I wonder how much (if any of this?) was going to battery warmup vs. just cabin heating?
Presumably the load stopped when I unhooked the car to drive to work.
I really want more diagnostic data about what is happening under the hood! What is the battery temp? How much heating is being done to the battery? How much heating is being done in the cabin?
