https://flowcharts.llnl.gov/content/energy/energy_archive/energy_flow_2013/2013USEnergy.png If you look a the fine print at the bottom of this chart, you'll see,More from LLNL
The upper right portion of the diagram depicts the split between energy that is successfully applied to end use and energy that is rejected to the environment. No energy transformation can be 100% efficient. For example, conversion of coal, natural gas, and nuclear energy in thermal power plants is, averaged over the existing fleet, about 35% efficient due to the fundamental thermodynamics governing the underlying technology. The remainder of the energy (on average 65% of the energy input) is rejected as waste heat to the environment. Most of this waste heat is often removed from power plants in cooling water, which drives the need for water for thermoelectric cooling. Electricity generation does not contribute directly to energy services because the useful result of electricity generation is consumed by the end use sectors.
This analysis does not calculate the efficiency of different forms of electricity production, nor does it assume a single efficiency for all power plants. Rather, it uses the difference between total energy inputs to electricity and total electricity produced to calculate rejected energy (see Appendix A.3.1)
Rejected Energy from Electricity Production: The electricity sector rejects more than half of the energy it consumes. Energy rejection from the electricity sector is calculated as the difference between the total amount of energy input into the electricity sector (described above as SEDS data-codes TEEIB-
ELNIB) and the total amount of electricity generated (described above as (Use + Exports)-Imports)).
"EIA reports consumption of renewable resources (i.e., hydro, wind, geothermal, and solar) for electricity in BTU-equivalent values by assuming a typical fossil fuel plant "heat rate."
This heat rate is likely in the neighborhood of 10,300 BTU/kWh, rather than the thermal equivalent of 3,412 BTU/kWh. The extra 6,888 BTU/kWh or so is accounted for as rejected energy, though it is a mere statistical adjustment, not physical energy.
So even as we converge to all renewable energy, these charts will still show a crapton of rejected energy. Their methodology is simply fossil fuel centric in outlook and must change at some point in time when we are more centered intellectually around renewable energy.
It would be far better in this chart to separate physical rejected energy from comparative non-physical rejected energy. That would show just how much progress is being made to reduce physical rejected energy.
