Should auto headlights work?
Discussion in 'Model S' started by BBB4000, Jan 29, 2017.
Tags:
  1. BBB4000
    BBB4000 Member
    VA
    I picked up a MS in mid December and since delivery my headlights always stay on. I have had 3-4 software updates and still no change. My questions to folks are:
    1) should auto headlights work and
    2) should auto highbeams work? Or is auto highbeam only part of certain packages?
  2. Haxster
    Haxster Member
    Silicon Valley
    #2 Haxster, Jan 29, 2017
    Similar issue on my mid-December MS. Off and Auto modes seem to both be Auto. In daylight, they do seem to eventually go off. Turn on again when I pull into the garage.
    I don't think that the auto high-beams are enabled yet on HW2. I guess the three forward-facing cameras can't figure out what to look for yet. Maybe Tesla should check out the "electric eye" on 1950s Cadillacs.
    I think all current Teslas come with auto high-beam dimming. But I could be wrong on this.
  3. theslimshadyist
    theslimshadyist NashVegas!
    Franklin, TN
    Auto brights haven't been enabled for AP2 cars just yet. Auto on/off finally started working correctly for me in the 17.3.2 update I received on 1/22.
  4. Shateam
    Shateam Member
    NJ
    Thanks @theslimshadyist So dumb question. When you say auto on/off started working correctly with the 17.3.2 update, does that mean the lights are completely off during the day or are the Daytime Running Lamps illuminated (i.e. the LED halo look)? Still haven't been able to figure out if we have DRL's.
  5. lunitiks
    lunitiks Cool James & Black Teacher
    Prawn Island, VC
    How about rain sensing? On AP1, the auto wipers, auto headlights on/off and auto screen dimming, all rely on the Hella light/rain sensor in the windshield - right next to the mobileye camera.
    Would be interesting to know if this is the same on AP2 cars.
    Auto high beams however, at least in AP2 cars, should rely on forward camera input data processing. That explains the missing auto high beams on AP2 cars - we know Tesla is still just beginning to implement functions that computes on the PX2...
  6. andrewket
    andrewket Well-Known Member
    All of these functions are using the front cameras on HW2.
    The auto headlight feature is enabled on HW2 now, but it tends to stay on longer then you might expect. When off, I believe the DRLs are now working, but there isn't a switch on the UI to manually turn them on/off like there is on US hw1 cars, at least not yet. In some markets the use of DRLs is required by law and the switch isn't there.
  7. Shateam
    Shateam Member
    NJ
    Thanks, that is helpful. So just to confirm...on HW2 cars (with the 17.x.x update) if its bright and sunny and I have the headlights setting to "Auto" (Range Mode --> "Off") then the DRL's should be illuminated. Same conditions with the headlights setting to "Off" then no DRL's?
  8. BBB4000
    BBB4000 Member
    VA
    I am not sure that is true for me. I am on the 17.x.x update and my lights are always on.
  9. reghoustonguy
    reghoustonguy Member
    Houston, TX, United States
    Just checked this yesterday off the car's reflection in front of me. Still on 2.52.xx - late Dec 2016 delivery. With headlights at auto and range mode off, DRL's are on during the day, and auto headlights work fine.
  10. _jal_
    _jal_ Member
    Chicago
    This seems to be a common question / complaint. I'm AP2 w/ 17.3.2 and auto headlights work, but IMHO the threshold for "it's light outside" is higher than I'm used to on other cars. In Chicago it has been cloudy almost every day this January, but during periods of sun the lights do turn off. During overcast days, though, the lights stay on even when maybe I'd assume they'd be off.
    It appears that DRLs are always on whether the lights are turned off automatically or via the control panel. And by DRLs I mean the LED halo / eyebrow lightbar.
  11. MorrisonHiker
    MorrisonHiker S 100D 2019.20.4.2
    Colorado
    #11 MorrisonHiker, Jan 30, 2017
    I can tell auto headlights have been improved in 17.3.15. When I was backing out of the garage yesterday, I noticed the lights were on. When I reached to turn them off, I saw they turned off automatically.
  12. croman
    croman Active Member
    Chicago, IL
    Mine have been working great (auto headlights). rain sensor is tied to forward cameras and isn't functioning (yet). Auto high beam and dimming is definitely not even being discussed. The DRLs stay on for me but headlights have a higher light threshold than most think. I don't mind as Chicago has been cloudy (gray stratus blanket) recently (but not today!) and 3/4 cloudy days had headlights on for some of the day but off for the brightest portions. DRLs look cool and are safer, so I'm all good with leaving those on all the time.
