If the Model 3 is rated at 1500 charge cycles, should I charge every day, assuming I study at 80% SOC and only go down to 70% on a daily basis. I'm looking to prolong battery life.
6. Whenever Supercharging, drive to the location using the Nav system so that the battery will precondition (if needed).As pre-warning, a lot of effort/worrying/effort over battery preservation beyond what's in the manual may only yield very small, maybe unnoticeable benefits in the time you own the car. Of course, outright abuse (charging to 100% frequently, deep discharge, lots of supercharging) may have a bigger effect.
Having said that...
As others have said shallow cycling is better than deep discharges - it's better to charge a little every day than run the battery down from 80% to 20% before charging.
Try to stay out of the fully charged and deep discharge ranges unless you need it for a trip (<20%, >90%).
Arguably being around 50% is the kindest place for the battery but it's not linear benefit so the difference between cycling 45%->55% vs 70%->80% may be small and not worth the fuss especially as you get the ability to do extra miles when needed without pre-planning in the latter case.
Finally, there's some been some folks that have caused themselves minor trouble with extreme cases of never charging to 80-90% (possible BMS calibration drift, possibly cell balancing issues).
If you want to read (a lot) more: How I Recovered Half of my Battery's Lost Capacity is a good place to start.
But TL;DR
- Shallow charge cycles are better
- Daily charging to 80-90% is fine
- Try not to deep discharge (<20%) unnecessarily - but if you need to do so on a trip don't sweat it.
- Don't fully charge (100%) unless you need it for a trip and try not to leave it sitting around at 100%
- Plug in the car when not in use as it can use shore power for preconditioning (and it's ready to do timed charging etc).
IF you can keep state of charge between 30% - 70% it might last easily a million miles. I don't think it would degrade at all.If the Model 3 is rated at 1500 charge cycles, should I charge every day, assuming I study at 80% SOC and only go down to 70% on a daily basis. I'm looking to prolong battery life.
Unlikely. First time degrades batteries even with zero driving. Second, lower than 50% creates more heat than above 50% which degrades batteries. Just charge to 90% and don't worry about it. There won't be enough difference in the degradation to notice.IF you can keep state of charge between 30% - 70% it might last easily a million miles. I don't think it would degrade at all.
I only think I know what I think I have read. You are no doubt more right than me. Can you remember/suggest article(s)/talk(s) that would help explain? just for my curiosityUnlikely. First time degrades batteries even with zero driving. Second, lower than 50% creates more heat than above 50% which degrades batteries. Just charge to 90% and don't worry about it. There won't be enough difference in the degradation to notice.
Google for battery university. Lots of information there although sometimes it's dated.I only think I know what I think I have read. You are no doubt more right than me. Can you remember/suggest article(s)/talk(s) that would help explain? just for my curiosity
Why own a vehicle if you aren't using it? Don't get a BEV to see how little you can degrade the battery - drive it - that is why it was made for.
And certainly don't obsess about battery life - ENJOY your ride. If you actually wear-out a battery - good for you - consider replacement.
PS - think I've read if you store a cell at a low temperature it won't degrade - you?
thanks.
(no reply expected, nor actually needed)
