Should Model 3 be offered as a Series rather than a Model?
Discussion in 'Model 3' started by FreeOfPge, Sep 19, 2014.
Tags:
  1. Yes
    5 vote(s)
    26.3%
  2. No
    13 vote(s)
    68.4%
  3. Not sure
    1 vote(s)
    5.3%
  1. FreeOfPge
    FreeOfPge Member
    Using Ford’s F Series as an example, the truck’s power, suspension and load capabilities are clearly differentiated by the nameplate, F-150, F-250, and F-350. Had Ford not done this, every F series truck would become Model F with either a 150, 250 or 350 badge.
    Presumably, Model E’s badges will be similar to Model S with two separate nameplates, one Model E nameplate and another power option (45 or 60) nameplate.
    Would it make more sense if Model 3 were offered in a series with each battery size having it’s own individual nameplate?
    Example:
    45kwh = Tesla E-45
    60kwh = Tesla E-60
    Changing to a series could be positive for both Tesla and Tesla’s customer:
    As a customer, when the time comes to resell my E-45 or E-60, it would be (more) directly compared against other E-45 or E-60s rather than every Model 3 available on the resale market.
    For Tesla, if slight body changes or trims need to be made to accommodate for something specific to one vehicle but not the other (i.e. more airflow to cool a larger battery), the change could be made to fewer vehicles.
    Note: to be clear, we don't know what size battery Tesla will offer in Model E, 45 kwh and 60 kwh are a guess.
  2. Kevin Harney
    Kevin Harney Active Member
    Herndon, VA
    Why is this important ? or of concern ?
  3. dsm363
    dsm363 Roadster + Sig Model S
    Nevada
    #3 dsm363, Sep 19, 2014
    Why did you start a second poll? I guess I don't see why Tesla wouldn't simply sell the Model 3 and provide different battery pack and trim options like they do now. Why lock people into the old way of doing things? Part of the advantage of doing a build to order sales model is people can build what they want.
  4. ElSupreme
    ElSupreme Model S 03182
    Atlanta, GA
    Well the F series trucks are very capably different between the divisions.
    And what you are talking about seems like semantics. MB uses 'Class', BMW uses 'Series', and Tesla uses 'Model' to designate their models. Putting a dash after 3 then the battery, versus the battery on the other side of the lift gate isn't really all that different.
  5. HankLloydRight
    HankLloydRight No Roads
    Connecticut
    I agree with this -- it's just semantics. It's like how the BMW E or F numbers work. Each E or F series cars are built upon the same basic frame/body/styling even across several model "years". Tesla is no different with the Model S/X/3. In terms of resale value of BMWs 3-series, the market always takes into consideration (at a minimum) the engine size, number of doors, etc so all "3-Series" cars aren't all lumped together. For Tesla, it will be battery size, performance model, and likely 2wd/4wd options. There's really no difference between "Model" and "Series" --- just that BMW uses their badging to further separate the trim lines (more for marketing), as Tesla is also already doing with "60" "85" (or "S85") "P85" and "P85+".
  6. caddieo
    caddieo Member
    Palm Coast, FL
    Amen, brother!! Current practice to differentiate S models is sufficient.
  7. KD5MDK
    KD5MDK Member
    Longhorn Country
    I like the convenience of knowing that a BMW 318i or a 335d or 335xi etc has consistent information embedded in the designation, but I'm sure the Model 3 will get appropriate shorthand soon enough.
  8. tom66
    tom66 Member
    United Kingdom
    Model 3 should be offered in four-door sedan initially. But they should have two-door and estate versions available later as well.
  9. Tasdevil
    Tasdevil Member
    Tasmania
    The BMW model numbers are based via engine size. As that's the draw card.
    Tesla Is known for making a fast car, so the only concern for "some" customers is range. Hence the models with different ranges.
    I hope in the near future tesla can offer 1 model that ticks the power and range boxes. Then all you do is choose your extra features.
    It's another way of showing the world that all you need is a battery and an electric motor.
    These ice engines that have turbos and superchargers on a 1.6L engine in order to get good fuel economy but still have some power should be portrayed as old school and pointless.
  10. Kevin Harney
    Herndon, VA
    AFAIK This used to be true for BMW but no longer is.
  11. HankLloydRight
    Connecticut
    Well I would say they are still "based on" engine size (loosely).. Whereas before they were actual indicators of size... Until the marketers got into the game and ruined it.
  12. Red Sage
    Red Sage The Cybernetic Samurai
    Los Angeles CA
    ≡S ... Sedan
    ≡W ... Wagon
    ≡X ... Crossover
    ≡H ... Hatchback
    ≡M ... Minivan
    ≡R ... Roadster
    ≡C ... Coupe
    ≡Z ... Supercar
    I'd like to see a Tesla Model ≡C P135+ Coupe...
  13. dsm363
    Nevada
    Please give the symbol a rest. Prince has a right to use a symbol that often but not many others do:)
  14. Red Sage
    Los Angeles CA
  15. ThosEM
    ThosEM Space Weatherman
    Annapolis, MD
    Don't forget the convertible!
  16. brianman
    brianman Burrito Founder
    No, really, he doesn't.
  17. Tedkidd
    Tedkidd Member
    Rochester, New York, United States
    +1 - though I'd rather they start with the estate (or at least hatchback) version. I suspect that's what much of the world would prefer also (besides US which has this bizarre thing against wagons).
