Hi everyone, just got my Model 3 MR yesterday and 110 charging will be sufficient for our driving needs.
My question is do I need to plug the Tesla into a GFCI socket. I have both in my garage (which may not be to code) but the non GFCI is way more convenient due to where I park the car.
If it should be GFCI can I just swap out the socket?
I have it plugged in now and it is charging at 5mph and shows 118 volts and 12/12 amps if that helps in your response.
I am absolutely loving the car but don't want to burn the house down!
Thanks in advance
T
Welcome to the Tesla family!
Several comments:
The "Universal Mobile Connector" AKA UMC Gen 2 that came with your car has built in GFCI circuitry. So from that box on the end of the cable to the car (including the connection to the car) you are protected from electrical shocks by that UMC. Providing a safe way to connect your car is the whole point of the UMC (and in fact, that is *all* it does - well, that plus telling the car how much current it is allowed to draw).
So whether you plug into a GFCI outlet or not, you still have GFCI protection when connecting the end of the cable to the car in the rain.
HOWEVER: If you plug the UMC into the wall to a non GFCI protected circuit and it was wet or something, you could get shocked because the GFCI protection in the UMC does not do any good upstream of the UMC (i.e. on the connection to your house).
Now the thing is, I can virtually guarantee you that any outlet in your garage or outside your house that you plugged into at 120v is likely already GFCI protected. Even if it is not physically a GFCI receptacle itself, it likely is "downstream" daisy chained off an existing outlet, or a GFCI breaker (less common). You can test this by tripping the GFCI using the test button and then going around and observing what receptacles stopped working.
I REALLY would not worry about plugging in an outlet in (or outside) your garage if it was dry where you were plugging in (whether or not that receptacle was GFCI protected).
I should also note that a GFCI has no impact on whether you are going to burn your house down. That is what the circuit breaker is for (to open the circuit if more than the rated amount of current flows through it). It will shut off the power before something heats up and catches fire. The GFCI is intended for human safety to keep you from getting shocked.
I am curious if your garage circuit is a 20a circuit (with 12 gauge wire). If so, you might be able to at least get the Tesla 5-20 adapter (and you might have to swap out the receptacle if it is not 20a rated). That would get you like 50% faster charging since moving from 12a to 16a actually is a big bump due to the fixed overhead losses in charging (running computers and cooling pump).
But really, I would encourage you to get a 240v charging solution going! Either some kind of 240v receptacle like a NEMA 14-50, OR a Wall Connector (I am partial to the Wall Connector myself so I can leave the UMC in my car at all times).
P.S. I also think it is safer to charge from a dedicated 240v receptacle rather than a 120v 15a or 20a circuit that is daisy chained among a bunch of receptacles. Just too many points of failure for my taste. I absolutely do it when I need to, but my daily charging at home is a hard wired Wall Connector at 60a (48a) and I have a dedicated 14-50 receptacle on a 50a circuit as well. If you post pictures of your breaker panel we can probably give you an idea of how difficult or expensive it might be if you did want to go for a 240v solution.
