Sean.
Certainly not a cheap thing to upgrade existing supplies. Much also depends on your particular DNO.Just a thought, obviously solar, battery storage and heat pumps have been talked about but should we have 3 phase? My reasoning Ali's that if EVs were made to charge at 22kW that would reduce home charging times significantly, easing the use of public network rapids. It would also mean that if the grid needed to be balanced the EVs (and battery storage) could pull more to help. Would also mean that we could supply more power to the grid when needed once we have V2G. Surely the added cost of installing this at the point of construction would be minimal?
I’ve upgraded two properties in the last 10 years. Each time not much change left from £10K just in DNO charges alone. They also charge you a pro rata proportion of Tx upgrade cost if it’s established that the local supply needs reinforcement. This is the real ouch factor. I’ve heard of some doozies in terms of what the DNO wants. If you’re in the sticks, be prepared to sit down when you see the charges as it could be as much as an M3 or more.
Otherwise it give a lot of flexibility- just don’t go looking for a smart meter suppler for 3-phase as there’s only one I know of in the country that offers them at the moment and it’s not a huge market. So your stuck with AMR and HH metering.
