Should there be any vibration on the steering wheel or is minor vibration normal?
Discussion in 'Model S: Interior & Exterior' started by Msolomi, Sep 1, 2013.
  1. Msolomi
    Msolomi Member
    Atlanta
    I had not noticed till today some vibration, but not sure i was ever looking out for it.
  2. Desdi
    Desdi Member
    Norway
    Get your wheels balanced to see if that helps. Thats what I would do first if its minor.
  3. SCW-Greg
    SCW-Greg Active Member
    Beaverton, OR
    I have a vibration in the steering when the HVAC is running hard. Took it in to the SC, they made it significantly better, but still there. I watched them as they worked on it, so was able to confirm no pipes or hoses resting on the steering shaft. It's just that AC motor vibrates quite a lot, even tho it's mounted on bushings. I still wonder if the behavior mine exhibits, is all that normal or not. I'll probably asked other locals about there experiences some more.
    You may have your Service Center, check yours out too. They know what to look for.
  4. Msolomi
    Msolomi Member
    Atlanta
    What I'm referring to is a slight vibration in the steering wheel when the AC is not on. Should I feel ANY vibration in the steering wheel when driving, even if slightly? Barely noticeable but curious. Thanks.
  5. DaveVa
    DaveVa Sig Perf #236 VIN #484
    Northern Virginia
    Alignment took care of my problem of vibration at speed (60 mph)
  6. jerry33
    Texas
    There should be no vibration whatsoever. The two main causes of vibration are unbalanced or improperly mounted tires and wheels and too much caster. The caster vibration gets worse as the speed increases. The tire/wheel vibration can do that (static balance), but more typically is worse at one particular speed (dynamic balance). Tire damage can also cause vibration problems, so check for bulges in the sidewall or tread.
