Should TMC discourage "+1 posts"?
Discussion in 'Site Feedback' started by Johan, Jan 1, 2015.
  1. Johan
    Johan Funds for M3 secured. Contingent on wife aproval.
    Drammen, Norway
    In browsing the TMC forum I feel I see too many posts quoting someone else and adding "+1". I believe this should be discouraged. You can instead use the "add to reputation" function if you only want to voice your approval of what someone else has posted without adding any new information yourself.
    Or maybe I'm just being grumpy?
  2. PaulusdB
    PaulusdB Mayor Gnomus Vintage Limb
    Europe
    -1
    the reputation change isn't seen by anyone but the giver and the receiver.
  3. Dave EV
    Dave EV Active Member
    San Diego
    +1 (hah!)
    Certainly the ones that just quote a huge post with a +1 and nothing else anyway. It would be nice if adding karma to a post also showed the number of times it was added via that post. Then we could easily eliminate +1 posts.
  4. Doug_G
    Doug_G Lead Moderator
    Ottawa, Canada
  5. SlyWombat
    SlyWombat Member
    Mississauga, ON, CA
  6. NigelM
    NigelM Recovering Member
    Northern Virginia
    The "+1" doesn't bother me, although the "+1,000" or "+1,000,000" is kinda silly...you only get one vote after all.
    (And wait for someone to write "+1,000,000" in 3,2,1,....)
  7. GSP
    GSP Member
    +1*10^34
    gsp
  8. gpetti
    gpetti Supporting Member
    Calgary, Canada
    If there was a like option the +1 would disappear along with many posts that are essentially just to void agreement. Easily said, not two easily implemented.
  9. Xenoilphobe
    Xenoilphobe Active Member
    Fairfax County Virginia
  10. bluenation
    bluenation Member
    vancouver
    there are forums which allow a Like function (same as Reputation on this forum, except requiring only 1 click as opposed to 3), and your name (ie. the 'liker") is publicly seen at the bottom of that post you just liked.
    my fav is certain hip hop forums, where they changed the wording from "like" to "daps"
    so for example
    "Bluenation, Johan, and Xenoilphobe give daps to this post".
    that shyt always cracked me up lol. always a sense of humor.
  11. Raffy.Roma
    Raffy.Roma Active Member
    Rome (Italy)
    According to me the + 1 is a very useful way to point out something very smart and good. Don't agree with the OP.
  12. Johan
    Drammen, Norway
    Question to the mods/Doug: is there no function that can be added to the forum in addition to the "reputation" such as some sort of "thumbs up"/"like" feature or some sort of upvote feature?
  13. mibaro2
    mibaro2 Member
    Georgetown, ON
    +/- 1
    Sometimes if I see a post that is exactly what I would have said, the +1 just sums up my reply.
    I noticed that there is a "rate thread" option , but you don't see the current status of the thread unless you click on it.
    I don't see a rate post option. If that option gets available, I also suggest there should be a 5 star rating beside the post which show its current status.
  14. jerry33
    Texas
    Having a +1 shows publicly you're in agreement with the post, although it's probably better to add a bit of detail as to why you're in agreement, or which part of the post you agree with. A "like" button would do the public part but not the why part, so there's pros and cons to each approach. I don't see any particular problem with the way it's done now. Bear in mind that almost every added feature puts more load on the server(s) and slows response slightly. (Slightly times a large number equals a large number.)
  15. gpetti
    Calgary, Canada
    The Like button wouldn't prevent people doing a plus 1 with additional comment if they so desired, it would just provide an alternative to people doing +1 without an comment. Incidentally the comment box doesn't normally like less than 3 characters so I normally have to stuff a space in there (not sure if there is some clever trick for this). I'm guessing that a Like button would put less load on the server than requesting and submitting a comment; however, I guess more people would do it than the number of people that currently do +1.
  16. scaesare
    scaesare Well-Known Member
    NoVA
    ~1
    (I don't care)
  17. Crispix
    Crispix Member
    San Diego
    I believe vBulletin does has a "like button" feature (as mentioned above) where people can just click the "like" button instead of posting a "+1". You can see the names of all the people who liked your post. How about enabling that?
    My other procrastination stop on the webz, scubaboard.com, has it enabled if anyone wants to see how it looks.
  18. NigelM
    Northern Virginia
    I highlighted the question to doug although I suspect it might be more than just click on a check box and presto the feature is there.
  19. Crispix
    Crispix Member
    San Diego
    If the reputation feature is already turned on and configured with proper permissions (and we know it is), enabling the Like button should be straightforward. The settings for reputation and like button are closely related, at least in some versions of vBulletin.
    Whether we should have the feature or not, that's an entirely different type of flying, altogether.
  20. linkster
    linkster Active Member
    USAX2
    + 1 :wink:
