LOL not quite what I was looking forI found this on the internet, but it isn't exactly inspiring...
Just wrapped my Black P100D in 3M 1080 line gloss deep blue metallic
In sunlight it looks absolutely stunning!
Ie. as if it was paint waxed 3x over...except. It’s only wrap
Dang, your car can best be described as "Beyonce wearing Deep Blue Yoga Pants"
Thanks, have never seen this color on a Tesla before
Thanks. I have actually looked at the Charcoal Metallic for mine.
Great color choice! This is a Model X we just finished in 3M Gloss Charcoal Metallic for reference.
Beautiful. May I ask...was there any wax or sealer you used on top of the vinyl to give it that extra shine? The deep blue metallic seems to look excellent in sunlight however in all other cases, the vinyl seems abt 80% of regular paint clear coat.
Also after 3-4 days now and with some good sunshine, certain areas are starting to pop? See pics. Is this normal and just requires a follow up visit to re adhere or heat/stretch back on?
As for the edges. The vinyl should not have those issues with proper install. It is time consuming but typically the mirror caps should be removed and done in one piece and all trim and lights should be removed to wrap underneath.
The vinyl on the edges show tension due overstretch and inproper installation technique. The lifted areas from the pictures are non repairable ans the whole panel has to be redone. The issue at fog light looks like bad trim from the photo and can be easily fixed.
Tesla is relatively easy car to wrap. It is true that it is time consuming but mirror caps does not have to be done in one piece if done properly. On tesla you don't have to remove hardware and trims. I remove the side blinkers only since it takes 30 sec to remove and saves tons of time on install.
I can post pics of the same areas on my S if you want which is done 6 months ago and survived Vegas summer without single issue.
Thanks for your reply Acho. Yes would appreciate some pics. I’m due to see the owner of the wrap shop today at 1pm to go over all the deficiencies. There are more as of yesterday
I’m trying to arm myself with enough knowledge to know what they must do to fix this issue.
Here’s a few more issues which surfaced after sun light for a few hours. The rear passenger light pic is by far the worst. Did they also not use a heat gun to ensure the wrap was adhered well??
What does a wrap job usually cost for a Model S?Thanks. I have actually looked at the Charcoal Metallic for mine.
I am sorry that you have such experience with your wrap
The tail light problem is not overstretch like the mirror and corners - beside bad cuts they did it looks like that they did not prep in the gap and it is not sticking.
I am wrapping cars for living and know very good what causes problems when I see them.
If you want to talk with me you can PM me and I will send you my number.
Pics to follow shortly
