Has anyone seen this used on a refresh Model S? When I checked the car at the showroom it seemed like it might fit in the same spot that the bracket is that ships from the factory. I wanted to have the factory bracket removed when I have an Xpel wrap done and also have this installed if it's possible but without a car to fit it on it's hard to tell if it would work. Hoping someone with a refresh nose can investigate some and report back.
Dimensions I found are 11 x 13 x 1 inches. It seemed like the bracket would have to go beyond the grill that is in front of the radiator but the grill felt like it had enough play that you could probably sneak the motor through it if you pulled down a little bit on it. Would be a nice touch to clean up the nose and avoid tickets.
License Plate Frames - Altec Products Inc.
