JerryNycom
Her is mine. Breyton LS 9x21 hyper silver ET 35 with alloygators and Michelin PSS 245/35-21.
Awesome effect! Nice rims :biggrin:
Your P85+ looks great! These photos and location are stunning! Photo skills A+++
22" Bulletproof Spec ADV.1 Wheels on our P85+
I assume the Breyton LS are a BMW fitment?
Bullet, do you get rubbing with those wheels? Do you have air or coil suspension? If air, any rubbing at "low" height?
Bulletproof,
I have some ADV.1 and have problems with brakes. It's has been discussed in other threads. Just wondering how your rims are working out.
What about drilling a small pocket into the rims (like the factory wheels)? The bolt doesn't look to protrude too far out.
Maybe another possible solution would to have a plate, with a hole cut out for the T45, that is sandwiched between the rotor and rim.
BTW, you mentioned spending $1000+ at the service center to fix this problem. Do they put on a different rotor? I would imagine it would be the same type of rotor.
Tobo65, did you replace your 21" to 19"?
I am looking to get the same wheel/tire combo you have on your car, but wondering if 19" tires really have less wear and last 30-40K miles compared to 15-20K I am getting with 21" contis now.
Thanks
Pramod
Yobigd20, I know original 19" tires last 40K miles. I wanted to know if original 21" tires from P85 are dropped to 19", they may not last as long due to several known issues with alignment and camber exclusive to 21" P85 or P85+.
You made the right choice choosing 19". Me and several others chose poorly that 6K upgrade for 21" wheels and now trying to downgrade.
I wanted to hear from other owners who dropped the tire size to 19" and still got similar mileage like you.
P
To my untutored eye, all the turbine wheels in this thread look like the factory wheels on my wife's P85+. No?? Is the intent simply to have the look of the factory 21" with a 19" wheel?
Just installed my new wheels:
ACE Convex 22 x 9 offset ET35
Tires: Vredestein 255/30 R22 (Sound emmission 67 db) - Not noticeably more noise than with 21" PS2
