RCH1708
Hi, I have an MX from Sept 2018 and it has had this problem since new. It's related to the TACC and can be induced - if you're brave enough - by sitting behind a truck with the TACC engaged, then briefly accelerating hard towards the truck, overriding the TACC, then taking your foot off the accelerator. This forces the TACC to brake hard (to avoid running up the back of the truck!) and usually results in a horrible noise from the front end. It sounds like sprung pressure relief valve oscillating or something. It's definitely hardware and not something that can be fixed with a firmware upgrade.
I've asked the Service Centre about it multiple times, but every time I'm told that its normal. Personally I don't believe a word of it - I suspect that it is a "cosmetic" problem with a poor quality component and that is too expensive for Tesla to replace. Eg similar to the 'yellow edge' problem of the central display screen.
If anyone has managed to get this problem solved, I'd be interested to know. I hate it.
