Shut down with supercharger in sight
Kenz
325
255
Hebron, Indiana
OK. I admit I am sans Tesla.....for now. But I do have a 2000 Honda Insight. And I do have several gas cars. The Honda Hybrid has a gas engine when the battery goes dead. BUT I would NEVER run my gas tank down to 3oz of gasoline (that is three shot glasses full). 3 Oz of gasoline represents 1 mile. What am I missing here that Tesla drivers will run till only one mile is left? I try to get gas in my Lexus when it tells me I have 50 (Fifty) miles of gasoline left. Is the Tesla so reliable that you really think ONE mile is safe????? I dont have sympathy for you.......
There is no excuse. Some people like to live on the edge. I know people with gas cars that don't fill up till is says empty.
Makes no sense to me. In an electric vehicles case it can also damage the battery. Make an extra stop along the way for 10 minutes, stretch your legs, get a coffee hit the restroom and go. The stress is not worth it. It is best to keep the battery between 20 - 80%. When you hit 20% look for a charger.
  • Disagree
Reactions: Evoforce and iclay
jackbowers
Jack Bowers
Aug 23, 2009
274
449
Sometimes there are unavoidable situations where cutting it close is the only logical option. A couple of years ago I was towing my Bowlus trailer home from the L.A. area. While traveling North on I-5, the Santa Clarita Supercharger went off-line while I was en route to it. Running the numbers in my head (2 range miles for each mile driven; 12 extra miles per 1000 foot elevation gain) it looked like I could drive 50 mph and clear the Grapevine summit with about 10 miles of range, then regen down to Tejon Ranch. Given a lack of destination charging alternatives (the Castaic RV park was likely full at the time) I decided to go for it, knowing that I could un-hitch an exit or two before the summit if the math didn't work out. But it did.
Big Ike
123
130
Arizona
@David99, I know you said you weren't paying attention, so this tip may not help, but I once was pretty tight en route to a Supercharger and decided to drop my trailer a few miles away from the charger, go charge, and come back to pick it back up. Having the car untethered on that last leg made it possible for me to make it.
If nothing else, a tip for others that are pulling a load in the future.
Great idea!
Big Ike
123
130
Arizona
It was bound to happen to me. For years I was bragging that I regularly drive my car down to single digits and it has never shut down. Now it finally did. And to punish me a little extra for my big mouth, it happened at 3:30 am just before the exit for the supercharger. I could literally see it. There goes the theory that the car will allow you to go a little extra if you are heading to a charger.
It was totally my own fault. I was pulling a trailer and my energy consumption was about double. At higher discharge rates the voltage drops faster and earlier at the end. I had 1 mile left when it shut down.
A few things to keep in mind when that happens:
Pull over as soon as you can. You have 5-10 seconds from the message popping up to loosing all motor power.
Since the 12 Volt battery isn't charged any more, get out of the car and let it be. This is your best bet to keep the 12 Volt battery alive until the tow truck arrives. Roll down the windows. When the 12 Volt battery dies opening or closing the door can break the windows.
Remember 'tow mode' is under the service tab.
Always have one of those external battery chargers for your phone. You are going to make many calls and do a lot of Googleing to find nearby chargers, and take lots of pictures and videos of your adventure LOL
The tow attachment thingy that came with my car is under the carpet in the frunk and you have to take the nose cone off to attach it. Just to mess with you when you are already stressed out, Tesla used a left tightening thread on it. WTF? I recommend making yourself familiar with your car and how it works so you know what to do in the situation.
One of those compact jump start battery packs can be a life saver. If you have to wait very long and the 12 Volt battery dies on you, you can't even plug in to charge the car. You first have to bring the 12 Volt system alive. One of those little batteries will do the job.
Always have a jacket and extra cloths in your car. Prepared as I am I was in my flip flops and shorts coming from California and freezing my butt off waiting at night in Iowa.
I wish Tesla would give the driver a little more time before cutting off power. The time you have might not be enough on a busy freeway and find a safe place to stop. There is zero heads up. I had ScanMyTesla app running and couldn't see any indicator that would have given a hit. The only thing that gives you some idea is the power limiter. If it's down to 80 kW, you are very close to a shut down. In general it helps a lot to drive very carefully and gentle when the battery is very low. By driving super careful I was able to get to 0 % without a shut down countless times. In this case, I didn't pay attention and kept driving at normal speed. With the trailer that was 60-80 kW.
Just a quick shout out for your honesty and humility! I appreciate the tidbits that you've shared.
Reactions: David99
Potatoee
31
19
Reading
This is a great thread. I am grateful that Tesla doesn't "dummy down" the car to protect me from myself and it exposes some of the engineering details to let me use the car as I see fit. I never agreed with having a BEV shut down prematurely to protect the car. There could easily be an emergency situation that would require taking the risk. We are all consenting adults (at least most of us ;-)), and I like that we can all take informed risks when it comes to how we use our cars. I think there is an analogy to FSD, WE are responsible for driving our cars and ensuring that we don't get into accidents. The only difference is that if we take chances by not being responsible drivers, we can hurt other people in addition to ourselves. Hands on the wheel people!
I love driving an intelligent car.
Jack007
189
143
Calgary AB
Ok, you pretty much summed it up for me, except plan your route to get to supercharger BEFORE 20%. In 117K KM it's only been yellow half a dozen times. I came close but NEVER got to single digit estimates. This is in a 75D.
However, I confess I didn't know I may or may not have a tow bar or how to operate it. So before I call people CIVILIANS (my worst swear word) I'll go look it up.
Jjmboni
24
18
Scappoose, OR
* Your Honda Hybrid can go over 400 miles on a tank of gas. A Tesla towing probably goes 100 miles or so (David99 would know more about that). So it's more likely that some people are pushing their cars to the limit given driving and trip distance.
* I routinely drove my newly purchased cars to empty so I'd understand what it's like. That way I know how far I can "push it" at my comfort level. When I first got my MX I drove it to 0 miles left as I was coasting into my driveway. Now I know what the X does when it gets that low.
* For some people, calling a Tow truck costs only $95 and some time. An ICE owner would pay that amount to fill their tank with gas! So I can see where some Tesla owners don't mind pushing it to Tow Truck levels since they're saving so much on gas anyway... :)
CuriousG
1,532
1,495
Elk Grove, CA
The problem is, with time, what you perceive as being able to go to 0 may not be valid any longer.
Reactions: Kenz
Farmer
63
95
Boston, MA suburb
Modern gas or diesel vehicles can be damaged when run empty as well. Some electric fuel pumps can be damaged by running dry. Diesel fuel systems sometimes need to be purged of air, and so on.
I became a 40 year driver this past spring and have yet to run out of fuel of any type in anything bigger than a lawn mower. I'm a wimp and just don't need that drama and aggravation in my life. My hat is off to all of you living the daring life.
fataldeadlock
29
11
South Oklahoma City
For road trips, it will be an issue until Superchargers are located every 25-50 miles. In my one year of driving a 2015 Model S 85, I have thus far encountered three scenarios where relying on the Tesla navigation could have got me stranded.
1. Road Closure. Driving from Illinois along I-44 to Oklahoma, the interstate was unexpectedly shutdown due to flooding. The shortest detour added 15 miles and 45 minutes to my drive. As others have mentioned, planning your trip to 10-20% arrival charge may not always work when factors outside your control arise (detours, power outages, distance to nearest public charger).
2. Remote Destinations. Driving to destinations that are not along the interstate. I took a day trip from Peoria, IL to Nauvoo, IL and back. Departing estimate said 15% to arrive back home. When setting out to depart home, the estimate dropped to 5%. Nearest supercharger was 116 miles away (2 hour detour) from Nauvoo, or I could drive 30 miles (40 minutes) out of the way for a 7.7 kw charger that would require another a minimum of 2 hours charging to even make the detour worth the effort. A definite 2.5 hour detour or risk it to make it home? Luckily, we made it home. Not sure if we would have made it had the outside temperature been 10-20 degrees colder.
3. Inaccurate BMS Range Estimating. My 2015 Model S now has upwards of 65,000 miles on it. On a recent road trip, I found that car is now having trouble estimating the time required to charge above 85%. For example, I set the car to charge to 100% at home before the trip. Two hours after the car should be been done charging (NEMA 14-50), it is still estimating that it needs 1 hour to finish charging.
Similar story as I stop at a Supercharger. I could stop to charge again in 60 miles, or charge up to 95% here and drive 180 miles to the next charger. I choose to aim for the 180 mile charger and set the car to charge to 100% at the Supercharger, it estimates 1 hr 10 minutes to full. Fine, I entertain myself with Netflix and come back 1 hr later, to which it still says 20 minutes remaining. I wait another 10 minutes and it still estimates 20 minutes remaining. To hell with it, it says I should arrive with 10% battery left so I set off with only ~90% charge. For the next 20-30 minutes of driving the estimated range is all over the place. For a few minutes, showing I need to slow down to 55 mph to reach my destination, then saying I will arrive with 15% charge. Once I drive for a bit, and the state of charge gets below 80%, the estimated range settles down and consistently says I will arrive with 7% charge. With conservative driving, I made it to the supercharger with 6% battery remaining.
When the battery is above 80% or below 20%, the range estimate is wildly inaccurate. After searching these forums, I have come to the conclusion that this is a common occurrence for cars with miles on them. This saddens me, as my daily charge routine is to set it 80%. I charge the car to 100% 2-3 times per year for the occasional road trip, and have perhaps 12 supercharger stops per year.
As I said, until Superchargers are located 25-50 miles in every direction and/or Level 2 chargers are available near every place of interest, there will be many circumstances that are out of your control. In my opinion, adding 2+ hours in detours for a road trip to compensate for lack of charging infrastructure is not reasonable. Therefore, there will be lots of people who push the range. Most times you will make it to your next charge sessions, sometimes you will end up stranded.
Rocky_H
5,848
6,684
Boise, ID
That's something I would never recommend, as it is too risky. The car's energy projections are pretty good for a continuous drive, but for drive one way, park, sit, wait, cool down (hours), and then do the return trip back, that's almost like two separate trips, and it's going to have higher energy use starting back on the return and a 15% margin is pretty tight for two trips like that with no charging in between.
I find it hard to believe that there could be many towns you could find that don't have some kind of Level 2 charging available. Can you name one? Almost every campground or RV park has Level 2 charging, and that's kind of a self-solving scenario, that the more remote you are away from large cities with J1772, the more campgrounds and RV parks there are, so Level 2 is almost everywhere. I would find it hard to believe there is a route that really can't be done because of no level2 charging available. Painfully slow, yes, but doable.
  • Disagree
Reactions: Evoforce and Kenz
Rocky_H
5,848
6,684
Boise, ID
I just love it when you have screwed up AND, you own it, but thats still not enough
Screwed up on something you didn't know about would be different. You hopefully learn a lesson from that first time and don't do it again. It was the several years of telling people you could drive below 0 that makes this in the schadenfreude category. I admit I was kind of waiting for this moment, because I had seen him recommending that to people a lot over the years, which I knew was going to turn out badly since he wasn't learning his lesson about it. It's a bit like if you get really lucky playing Russian Roulette several times in a row, so you continually tell people it's not dangerous.
David99
4,850
7,021
Brea, Orange County
Apples and oranges. You can't compare a gasoline car to an EV in this scenario. With a a gas car you can just pull I to the next gas station when you reach your comfort level. With an EV you simply don't have that luxury. I have driven 6000 miles with a trailer on my Model S. There are many sections where there is no chargers in between. It's a 120 mile leg with elevation climb. I have to make it. If I drive 45 I can barely make it. I'm not driving it low because I like living on the edge. I have no choice. Everyone on the freeway is already annoyed that I'm crawling at 45.
And yes, after driving 240k miles in my Tesla, it has consistently been so accurate that I was able to drive it down to single digits.
In an EV your range is limited and your charging options are limited. It's not a choice to maximize the available range, it's a necessity in some situations.
Reactions: Evoforce
David99
4,850
7,021
Brea, Orange County
There is no excuse....
There is no charger when you reach 20%. It takes excessive amount of time to charge to 100% (unlike a gas tank).
You can't compare gas and EV this way.
Reactions: Evoforce
cch1
16
11
Central Virginia
Annoying passengers and In-laws are fair game too.
