I have an intermittent problem with the side cameras not turning on until 12-25 seconds after I shift into reverse. I have performed all resets, incl Factory Reset, to no avail.
I HAVE been able to duplicate the symptom by getting into the car for the first time in a day, pressing brake, and almost immediately shifting into reverse.
Why it's a problem: When I back out of the garage, I am sometimes out of eth driveway and into the street before the side cameras turn on.
Subsequent drives don't regularly exhibit the symptoms (maybe car isn't going into as deep a sleep between drives). Further, I have found that if I wait several seconds after pressing the brake before shifting into reverse, I usually won't see the issue.
My primary concern: Is this a problem for anyone else?
If I have to just be patient and count to 5 before shifting into reverse, so be it. But if nobody else is encountering this, I'd like Tesla to look at it.
In a past conversation with Tesla service in which I shared that I used to be able to jump in the car, press the brake, and almost immediately shift into reverse, but that with later versions of the software, the car seems to need to have a second or two to fully "boot" before shifting into gear. The explanation (and a plausible one): "Lots of processes are starting up when you wake the car with the brake...more processes than before (with earlier SW)." Advice: Be patient.
I get it. You can't expect to use a PC immediately after turning it on, either.
I'm wondering if this "side camera delay" might fall into the same category.
