Side mirror trim rubbing paint off door jambs
Discussion in 'Model S: Interior & Exterior' started by Nikoli, Feb 16, 2014.
  1. Nikoli
    Nikoli Member
    Cincinnati, Ohio
    Check your paint on the front door jambs by the side mirror trim. My trim is rubbing away the paint. Driver side is completely through to the metal and the passenger side is getting there. The wear point is visible on the chrome as well. Service is looking at it this week.
  2. darthvdr
    darthvdr Member
    los gatos, ca
    This is astonishing. Did you get a chance to talk with service? This should be covered by Tesla's warranty.
  3. huntjo
    huntjo Member
    Fort Collins, Colorado
    Eww, yeah! That sux. I'm sure they will replace it, but wonder if it is caused by a singular episode of poor fit or if others will find similar wear
  4. wormhole
    wormhole Banned
    Westchester, New York
    can you post a pic further away, apologies but i still can't tell where this is happening so I can check...that's remarkable though
  5. ckessel
    ckessel Active Member
    +1, it's too close for me to figure out where this is on the car.
  6. caddieo
    caddieo Member
    Palm Coast, FL
  7. Pmeyer1106
    Pmeyer1106 Member
    Covina, California
    I just checked the location of my mirrors and, at the closest, the trim is 1/4 in. from the fender. Does your trim extend past the edge of the door?
    - - - Updated - - -
    Sorry, 1/8in. not 1/4.
  8. Nikoli
    Nikoli Member
    Cincinnati, Ohio
    The first pic is an extreme close up of the door jamb (on the car's body) at the end of the A-pillar just below where the chrome body trim ends. Its the point where the front fender, A-pillar, and side mirror trim come together. The chip is approximately 3/8" in diameter. The second pic is the end of the mirror chrome showing the two points making contact with the body. The chrome is perfectly clean and dried, those discolorations are from contact with the body. There are two spots, the upper-center point matches where the paint is worn through to bare metal and the lower-left matches a spot showing wear but has not broken through the paint yet. You have to open the door, crouch down, and look up slightly to see the location. Service center reports the doors need to be adjusted slightly. I have 14,000 miles on my car and it's an early vin, P02205.
    Below is a pic of the loaner from a similar angle.
  9. caddieo
    caddieo Member
    Palm Coast, FL
    #9 caddieo, Feb 17, 2014
    I just checked both front doors after reading your post and I see no defects like yours. With the doors closed, I can easily slip a thin piece of cardboard (cereal box top) between the end of the chrome strip and the body. And at the extreme open position, I can easily insinuate the tip of my pinky. So perhaps service is right about the doors needing adjustment.
  10. TylerCA
    TylerCA Member
    portola valley, ca
    I had rubbing issues similar to yours, but mine was on the hood. It was not enough to scratch down to bare metal, but enough to create some scratches on the top triangular edge of the hood onto the side panel. Brought it up during service and they readjusted the hood so it is no longer touching. Definitely bring this up to your service advisor.
