Sidewall tire damage pics
Discussion in 'Model S: Interior & Exterior' started by plasmo, Sep 26, 2018.
Tags:
  1. plasmo
    plasmo Member
    Chicago
    I’m planning on taking this into my Tesla SC but before I do so, just wanted to post pics of my right rear tire showing sidewall damage to see if anyone thinks that this might be salvageable. I’m expecting that I will need a new tire(s).
    There is no bulging of the tire. I’m not sure how long this has been like this either. Tire is currently 1 year old.
  2. ACA Man
    ACA Man Member
    Rancho Cucamonga
    You'd need a new tire and probably you'd need to replace the other on the same axle.
    Don't buy tires from Tesla...they will charge you full retail.
  3. plasmo
    plasmo Member
    Chicago
    Thanks. The Model S is leased. Do I need to go to Tesla, or can I go anywhere to get this fixed?
  4. Lasttoy
    Lasttoy Active Member
    St Augustine, Fl
    Get from Tire Rack. I got 4 yesterday.. paid my local shop $60 for mount and balance.
    Less than my shop can pay. Never ever buy from Tesla.
    Looks like you hit curb? Rim will clean up.
  5. Doanster1
    Doanster1 Member
    Oregon
    Wisdom says replace it since the curb that rashed your wheel took a decent slice out of the tire as well. Just drop by your local tire shop (America’s/Discount Tire) and they’ll get you squared away. They match Tire Rack, etc. on price.
  6. IchDochNicht
    IchDochNicht Member
    Bay Area, CA
    I first went to wheel works, but found out their tires didn't have the foam inserts of the originals. And they got fatty fingerprints all over my car. Then I drove-by the Tesla SC, but they didn't have an appointment. Sent their mobile service the next day. Super friendly, didn't touch anything but the jack points and wheels. The only downside of the mobile service is that they don't have a road force balancer in the vehicles. Cost was a little higher, but worth it.
  7. ACA Man
    ACA Man Member
    Rancho Cucamonga
    You can go anywhere to get it done.
    Personally, Costco is the place.
  8. plasmo
    plasmo Member
    Chicago
    Thanks.
    Have you had any issues with Costco? Like not having those foam inserts (whatever they is) another person mentioned above...
  9. EVSteve
    EVSteve 110% Solar Powered
    Schnecksville, PA
    Why would he need to replace the opposing tire?
  10. brkaus
    brkaus Well-Known Member
    Austin, TX
    Studies are pretty mixed on the benefit of the foam inserts.
    I need tires too. Putting off due to indecision.
  11. Saimaannorppa
    Saimaannorppa Member
    Finland
    I had a similar slice on my rear tire too. Shorter but perhaps a little deeper. It has caused no problems. If the cut is only in overlaying rubber I wouldn’t bother to replace. In fact now that this reminded me, I went into garage and used rubber cement to fix it. I have used same stuff succesfully to permanently fix a hole caused by a screw through the rubber.
  12. scottm
    scottm Legacy account
    Canada
    Personally, I'd contact cement that down and see how it holds as you're making up your mind if ... after a while you'll probably forget about it and if it doesn't bulge or lose air over a month or two... you'll completely forget about it.
  13. EVSteve
    Schnecksville, PA
    I fail to understand why people roll the dice when it comes to tire damages. At highway speed a tire failure could kill you. In bad weather being stranded with a flat is also a bad situation. Saving a few hundred on a tire is not worth the risk.
  14. plasmo
    plasmo Member
    Chicago
    Completely agree with you. No doubt I’m going to replace the tire(s). Plus it’s my wife’s car and would hate this hanging over my head if something happened.
  15. ACA Man
    ACA Man Member
    Rancho Cucamonga
    To have the same condition as the damaged one.
  16. ACA Man
    ACA Man Member
    Rancho Cucamonga
    I can't say for sure.
    We used Costco for all of our tires needs until the MS which I already bought a spare set right on this forum.
  17. scottm
    Canada
    Q: Just curious, do the OE tires come with a road hazard warranty that will help out with the cost of new ones in case of road damage on original tires on original wheels from the factory? Maybe prorated on tread remaining.. They may exclude curb hits, etc... but.. anybody know?
    It's been so long and I'm no longer on OE tires so the only warranties I pay attention to are the aftermarket tire shops I use... Costco, Kal Tire..
  18. plasmo
    plasmo Member
    Chicago
    Just purchased two Goodyear Eagle Touring SoundComfort Technology tires (P245/45R19) for $249 x 2 online and my local Just Tires is going to install ($19/ea) when they arrive. I believe these tires are the exact same ones I have now. Hopefully this is a decent price.
  19. EVSteve
    Schnecksville, PA
    His tires are only a year old. Unless a lot of miles have been logged the tread depth difference should be minimal.
  20. ACA Man
    ACA Man Member
    Rancho Cucamonga
    Correct.
