Since my MC2/HW3 upgrade, the car will not sleep when plugged in
Discussion in 'Model X' started by BlueBird, Aug 29, 2020.
  1. particleman
    particleman Member
    Indiana
    Well I jumped the gun on this one and can also confirm it isn't fixed. The car is sleeping initially but at some point later in the evening waking up. I'm still seeing the screen burn I posted the photo of from the screen staying on so long.
  2. tommytuna
    tommytuna Member
    Toronto, ON
    Did 2020.48.30 fix it?
  3. BlueBird
    BlueBird Member
    Chelsea, Québec
    Unfortunately nothing changed with this version and this is getting very annoying during our winter season. I just cannot imagine letting my car start and stop every 15 minutes.
  4. brkaus
    brkaus Well-Known Member
    Austin, TX
    It will wake up to check the temp and decide if the pack needs heat. Have no idea what the thresholds would be for that check and heating.
  5. WinterX
    WinterX Member
    Austin
    I've been experiencing the same. I installed TeslaMate just to confirm my suspicion. Car sleep and wakes at set intervals.
  6. brkaus
    Austin, TX
    Mine does too -
    It’s still MCU1.
  7. tommytuna
    tommytuna Member
    Toronto, ON
    I am wondering if recent temperate drop in Toronto area (very cold nights) is causing this. The garage stays above freezing but my last temp reading was only 2C. Could this be the culprit?
    Also noticed massive amounts of data uploaded to Tesla last couple nights - 5GB in last 24 hours alone! Maybe i'll try to turn off car wifi although it keeps coming back after each drive. Figure Tesla wouldn't upload all that data if it was only getting a LTE connection.
  8. WinterX
    WinterX Member
    Austin
    Although below freezing outside last night, my garage here in Austin rarely gets below 50F in the winter (as well as Austin rarely getting too cold). I've been experiencing this constant awake/sleep cycle since 2020.48.*
    My office is on the same wall as the garage/Tesla wall charger. I've been listening to it wake and the relays open/close on the wall unit for over a month, it led me to installing TeslaMate on a VM here just to confirm. It's pretty annoying, but one can't think that it is very healthy for the long term either.
    Car is waking/sleeping 60+ times a day while its in a closed garage, on wifi, and plugged into a wall charger.
    W/ Brakus experiencing the same thing, and being on an MCU1, well who knows what the interconnection is, other than a bug. Hope they're aware of it and will get it fixed for this "Holiday Update" coming June 2021 :D
  9. tommytuna
    tommytuna Member
    Toronto, ON
    yes seems firmware related - i've got appt with SC on Friday to fix repeater cams - i will mention to them as well.
  10. particleman
    particleman Member
    Indiana
    I just had an unrelated service visit and included information about this issue on the request. They confirmed it is a known issue and a fix will roll out eventually.
  11. tommytuna
    tommytuna Member
    Toronto, ON
    Had my car in for service to fix fender cam and asked them to change 12V battery as well. Funny enough last night the car slept and phantom drain down. Wonder if it was constantly charging the old 12V?
  12. WinterX
    WinterX Member
    Austin
    Awesome, thank you for that update.
    What reasoning do you need to give to have them change out the 12V?
  13. BlueBird
    BlueBird Member
    Chelsea, Québec
    My problem appears to be resolved after installing build 2021.4.6. I was able to leave my car plugged in and sleeping now for over 30 hours. I am not sure if the problem was resolved in a previous build as I did not run more testing until now.
  14. BlueBird
    BlueBird Member
    Chelsea, Québec
    Need more testing but possibly false hope with 2021.4.6! The car slept for almost 3 days and yesterday, after waking-up, it started the on-off cycle again without any good reason. VERY ANNOYING!!!
  15. gangzoom
    gangzoom Active Member
    Uk
    ^ Am not convinced anything has changed....
  16. WinterX
    WinterX Member
    Austin
    I'm on 2021.4.6 and my X still wakes up on a preset interval upload_2021-2-24_10-38-44.png
