Sirius XM radio static
Fxnbonz
23
23
Windermere, Fl
I have model X that I purchased in October 2019. I have all access SiriusXM. Periodically, I will get significant static in the radio. The static is only with Sirius. Streaming, tunein, FM is fine. Signal refresh did not resolve the problem. I had to power cycle the radio by switching off Sirius, then doing a signal refresh. Once I do this, everything sounds perfect. I have had to do this twice. It worked for about 2 weeks. I’m thinking this maybe a software issue. If you have had this problem, please share your experience.
araxara
S-P85#3,218 X-LR M3AWD
May 11, 2012
1,012
380
Tucson, AZ
I get this too on my Raven Model X. For me it's a crackling sound. But rebooting the the car with the scroll wheels fixes it. I have other problems, including the XM stations dropping out and coming back. Also, the XM radio goes away completely and only doing a power down of the car will fix it.
There are many discussions regarding this problem. There is even one at the "official" tesla.com forum: SiriusXM Issues | Tesla
ajdelange
1,077
540
Virginia/Quebec
Sirius transmits digitally. With a digital system there is no noise. If perfect reception is not possible then the packet is dropped (the audio output is silenced). Thus it's not a problem with Sirius. It's a problem with the way the car's computer handles the audio. The fact that resetting the computer resolves the problem (if temporarily) is proof positive of this.
Reactions: sefar and boaterva
bob_p
3,594
2,748
In the past, the onboard media player has had problems with USB/streaming audio - with periodic pauses or dropouts - caused by software problems.
Because XM is transmitted digitally - if you're hearing any audio from XM, it should be without static. If you were having a signal problem - you'd be getting dropouts (periods without any audio at all) and not static.
If the issue is only with XM, that rules out interference in the signals being sent to the speakers (bad or loose connection).
So the likely cause is a software issue - something in your vehicle or configuration that's causing a conflict while XM is running - and by rebooting, you're eliminating that conflict (at least for a short time).
When this happens, recommend doing a "bug report" through the car's voice system - and hopefully if Tesla gets enough reports on this, they'll be able to find the problem and implement a solution.
Not seeing this on our 2017 S or 2018 X when we listen to XM.
davezforce
IG @davezforce
Jan 18, 2017
495
240
NJ
Same issues. How do you do a big report?
PM90D
6
0
Socal
I notice the crackling sound only when playing music via blue tooth. Autoplay bug will start your audio without your interaction so dbl check it. Gets rid of the crackling for me.
davezforce
IG @davezforce
Jan 18, 2017
495
240
NJ
I have to say after the .36.2.1 update for the past 4 days my xm has been working flawlessly. Maybe they fixed it. Anyone else notice a difference?
araxara
May 11, 2012
1,012
380
Tucson, AZ
Yes, I noticed that it has been much better. Right after the .36.2.1 update I did get some clicking/static noise, which was remedied via a scroll wheel restart. Sometimes, when I come back to the car (mostly overnight), I noticed that the XM radio is on Station 0 (XM ID), but I am still able to switch to my last station.
I did a 4 hour drive last weekend with no problems. Actually, I got bored listening to XM some times and switch to USB. In the past, XM would cut out and I would have to fiddle with it and would get frustrated. This time it didn't have any problems. I will be doing a longer drive this weekend and will see if it continues to behave.
Reactions: davezforce
Canucken275
15
-1
Portland OR
We haven't had that issue (Model X) but we get a ton of fade in and fade out. The antenna on the X is dreadful. We've had Sirius for well over 10 years on several vehicles and never had this issue. The other problem with Sirius on the car is that it doesn't play on the rear speakers, only the front. FM, streaming, phone will play 'normally' but not Sirius. Oh, and one other thing. I'm still annoyed they took away the categories. Trying to find stations now is terrible.
araxara
May 11, 2012
1,012
380
Tucson, AZ
Are you talking about these Categories:
Brave Ulysses
206
133
Denver
The categories seem to come and go for no reason.
I have the static, and it pops up pretty frequently. Before V10 I didn't have any issue with static on XM stations. since then I have it, including with the latest update. software reboot fixes it but only for a few minutes or a few hours. very frustrating.
