golferguy
Unfortunately even my Model X will lose signal under heavy trees on occasion.Does anyone have a suggestion for a different antenna or mounting location?
I live in a very wooded area and can't get a constantly good signal in my driveway and most of my neighborhood. I had it mounted per White-on-White-MY under the trim. and I've 3d printed a mount Dude7 and still get very sketchy reception. I've finally moved the antenna to the roof, until I find a better solution. This has worked better than other internally, but it still cuts out often.
I believe if I had a larger surface area antenna it may work better with lots of trees, Maybe a wire antenna I could mount between the across the glass?
Any internal antenna will perform worse than an external antenna, provided its attached to a magnetic surface. External is your best bet to solve/reduce it.
