Site formatting broken
Discussion in 'Site Feedback' started by XrstalLens, Jul 18, 2012.
  1. XrstalLens
    XrstalLens Model S P1327 VIN P01867
    Kirkland, WA
    Starting today I'm seeing a bunch of formatting problems on this site. Is anyone else seeing this? IE 9.0.8112.16421 (32-bit and 64-bit editions). Three different machines and two different networks.
  2. brianman
    brianman Burrito Founder
    I've been seeing it on mine as well. Last day or so.
    Not quite as bad as what your screenshots show, though.
  3. W.Petefish
    W.Petefish Active Member
    Seeing the same with Chrome.
  4. XrstalLens
    Kirkland, WA
    I tried it on iPad Safari as well - same symptoms.
  5. doug
    doug Administrator / Head Moderator
    SF Bay Area
    Yeah, not exactly sure what happened. The "TMC" style originates from some previous version of vBulletin.
    Tracking down those sort of problems is supposed to be MPT's job and I alerted him via email some hours ago. In the mean time I made a new vanilla style that is at least native to vB4 and stuck our header on it.
    So change the style to "TMC--vB4". Though it's not perfect, it's better actually in a lot of ways, so try it out.
  6. XrstalLens
    Kirkland, WA
    #6 XrstalLens, Jul 19, 2012
    Forum Tools drop down has invisible text
    The "Forum Tools" drop down you get when reading a forum has had invisible text as long as I've been using the site. It happens on Safari and IE. If you hover over the items you can see them as you hover, so it's been workable, but it would be nice to get that fixed. I figured I'd report it since it has been that way for months now.
    Thanks!
    Edit - changing to the TMC -vB4 style remedies this problem as well...
  7. XrstalLens
    Kirkland, WA
    That works great - thanks!
  8. doug
    SF Bay Area
    Glad someone is happy. This actually solves a ton of minor formatting issues, like that invisible forum tools menu.
  9. dsm363
    dsm363 Roadster + Sig Model S
    Nevada
    That does fix the problem. Thanks. I kind of like the old TMC style with the high contrast between new (red) and old posts so if it's possible to fix that as well or alter the new version, that'd be great too. The TMC-vB4 seems to blend these together with more similar shades.
  10. XrstalLens
    Kirkland, WA
    So, now that the TMC theme is fixed, and TMC -vB4 is no longer an option, this issue is back...
  11. doug
    SF Bay Area
    Yeah, sorry about that. We're going to work on it a bit and then bring that option back.
