Sitting without charging
Discussion in 'Model S: Battery & Charging' started by rw86347, Dec 8, 2016.
  1. rw86347
    rw86347 Member
    denver, co
    My Nissan Leaf can only sit for three weeks with out being driven or else the lead acid battery will die (even if plugged in). Is that true with the Tesla?
    Last time I took a business trip to china I came home to a dead car, which was also plugged in.
  2. roblab
    roblab Active Member
    Angwin (Napa Valley) CA
    I understand that a Tesla loses about 3 miles per day sitting. So, it seems that you would lose maybe 65 or so miles. If you drove a ways, you might come back to a low battery, but probably not. That's the nice thing about having 300 miles (well, if you own a 90D) instead of 80 miles or less (as in owning a Leaf).
  3. sdorn
    sdorn Director of Awesome
    Georgia
    I think the car will charge the 12v battery automatically if you keep it plugged in, so that shouldn't happen. I would be interested to see what others say though. I don't have my car yet.
    This thread isn't exactly on that point, but it is related and had some interesting information about the 12v battery.
    Any reason not to hook up a battery tender to the 12 volt battery ?
  4. Rocky_H
    Rocky_H Active Member
    Boise, ID
    Tesla cars do always monitor the level of the 12V battery and will kick in a cycle to refill it from the main high voltage battery as needed. I think this usually happens at least a couple of times a day. So unless something goes defective, in normal operation, it will never let the 12V battery die like you mentioned with the Leaf case.
  5. wesley888
    wesley888 Member
    Huntington Station, NY
    I've monitored my 90D in the last 3 days. It seems to lose about 1 mile per day. Any way to get a more precise reading?
  6. David99
    David99 Active Member
    Brea, Orange County
    Tesla keeps the 12 Volt battery charged, nothing you need to do. How much energy the Tesla main battery looses depends on a few factors. Many people use a data logger that connects to the car every minute when parked preventing the car to truly go in sleep mode. This will cause higher losses. It's best to keep the Tesla plugged in when not in use and set the charge limiter to 50%. If you can't plug it in and want to keep the losses to a minimum, turn on energy saving mode and turn off remote access.
  7. Saghost
    Saghost Well-Known Member
    Delaware
    Remote S gives a rated range reading with two decimal places. I don't think it can actually read to the hundredth of a mile, but it can certainly show partial mile changes and whatever the highest level of precision Tesla's API supports.
  8. brkaus
    brkaus Active Member
    Austin, TX
    The Tesla does not have that problem.
