Size of USB drive needed for TeslaCam?
Trekboy
25
29
Redding, CA
Just got a usb adapter and endurance 128gb microsd. No issues
I will second this recommendation. The "Endurance" micro SD cards are made for continual writing, unlike a normal USB thumb drive. These are specifically marketed for security cameras and dashcams. Also, they're rated to function in high temps like 185 degrees F. This is what I bought and I get no errors now.
6
7
Seattle
All these flashdrive errors are likely attributed to them getting corrupt and failing from the excessive dashcam read\write cycles. It's not a speed issue, it's a cycle issue.
Highly recommend an endurance type card.
SanDisk 256gb Endurance
Samsung 128gb Endurance
As for the ease of viewing. I have an Android personally and use the TeslaCam Reviewer app. With this 4 in 1 SD Card Reader Adapter I can review any clips quick and easy. The app shows you all 3 cameras at once and ability to play at high speed.
Yes. For everyone else’s benefit, cycles here is referred to as the number of read/write life cycle. For SLC (high-endurance) it can support up to 100,000 cycles vs 5,000-10,000 on MLC flash (i.e.,cheap usb memory sticks) so you can see why the usb ones will start to throw errors sooner.
Reactions: Kbra and Scott7
skip8jj
261
110
Portland, OR
Recently... maybe the past month or two? Don't recall the exact firmware version. I'm currently on 24.4 and ext4 works.
Where do you find "ext4"? My only options on my MAC are "macOS extended, journaled, macOS extended, journaled case sensitive, ExFAT and MOS-DOs (FAT). Very confusing all of this. Thanks
john85775
386
437
Use MS-DOS (FAT). That is actually FAT32 (needlessly confusing I know).
Hugh-SG
80
84
Vancovuer, BC
the bigger the better. I have a 256 gb sandisk ultrafit and a 128 gb on standby. Seems no matter what eventually the drive fills up and needs to be reformatted. One of these days they'll build that feature directly into the car - "your usb drive is full, ok to reformat?" or USB drive corrupt, press OK to repair.
If I may suggest, (and much simplier), "Loop and Over Write oldest files?" Yes - No
Now we request the addition of two more Foldiers..
2nd folder "tesla-saves", where any Impact Trigger, Emergency Braking Trigger occurs or a User "Save" Button is pressed.
3rd folder "tesla-sentry", where there is a Side Cam Motion Trigger, or Window Break, or Bump (vehicle motion) Trigger.
Then Sentry mode would behave just like my ThinkPro F200 dash cam.
Food for thought...
Cheers, Hugh-SG
Reactions: cybergates and Wick
ecospider5
32
51
Duvall
You shouldn't need to reformat it- just delete the files you don't need.
Since the car can't know which Sentry or other saved video is important it can't just randomly delete that stuff automatically.
I reformat because it is faster in windows 10 to do that than deleting 256gb of files.
ecospider5
32
51
Duvall
Not really sure what your question is. I think you are referring to the size of the USB stick that's needed for TeslaCam. I do not believe there's a minimum size required. However the bigger the size, the better. Depending on how you use it, it can fill up rather quickly. At the very least, I wouldn't do anything smaller than a 16gb
Also since this fills up the drive on a regular basis a high endurance Micro SD card will last longer and you won’t have to deal with the files constantly getting corrupted in 2 years.
SanDisk 256GB High Endurance Video microSDXC Card with Adapter for Dash cam and Home Monitoring Systems - C10, U3, V30, 4K UHD, Micro SD Card - SDSQQNR-256G-GN6IA https://www.amazon.com/dp/B07P4HBRMV/ref=cm_sw_r_cp_api_i_mRBxDbN9AJSZR
Reactions: jdw and asterothe
brucekrymow
9
3
Arizona
New Tesla S owner - I've seen voluminous posts scattered here and there throughout the site when searching... but are there any go-to definitive guides anywhere w/ clear, precice directions are available where a a new Tesla owner can set up the the Tesla Dash Cam, and for setting up the SentryMode recording/viewing/etc.?
sduck
Mr. Duck
Nov 6, 2017
1,388
1,394
Nashville TN
You'll need some additional tools to use ext4 with a mac - there's a command line way, or Paragon Software makes a (nonfree) utility addon. It's normally a linux thing.
Aberrant
New Member
Aug 14, 2019
4
6
Oregon
Can you recommend me an exact drive that works for you?
I had a lot of trouble with corruption using Sandisk and Kingston USB drives. I read that MLC NAND - type memory holds up better for dashcam use.
Both Transcend and Mushkin make drives that use this type of memory. I purchased a 256GB Mushkin Impact USB 3.0.
So far, no issues after 4 months and 6,000 miles of TeslaCam and Sentry use.
Reactions: Scott7
SVMike
263
326
Silicon Valley
I'm sure that the high endurance drives are better. But if you fill up your flash drive every day and it only gets 5000 cycles you will be sad because it will only last for 13 years and 8 months. Maybe you'll get lucky and go for 10,000 cycles so you'll get to 27 years.
Knightshade
11,150
14,457
NC
Yeah. With a 128 or 256 GB drive, literally any brand or type, it'll take at least 5-10 years before you approach the rated # of write cycles for even the cheapest/crappiest flash memory used in such drives.
The high endurance stuff is worth mentioning for multiple-4k-camera aftermarket setups where massively more data is being written constantly- but not so much for Teslacam situation where it's taking days at a time to use a single full write cycle.
David Kirchner
New Member
Aug 8, 2019
3
4
Windfall, IN
There is another storage option not mentioned here. At forums.Tesla.com they have a thread "Raspberry Pi uploads Dashcam & Sentry videos to my NAS". I am personally looking into geeking out on Pi. This transfer files over your home WiFi to your NAS and you can schedule house cleaning. (for the computer technology inclined)
Knightshade
11,150
14,457
NC
quite a few threads on that method have been posted here, including links to the relevant github projects with the code to do it with essentially a 1-step setup, so only marginal tech inclination needed :)
