SKF Beyond Zero TV - Tesla
Discussion in 'Video' started by wart, Jun 12, 2014.
Tags:
  1. wart
    wart Nosecone Member
    San Antonio, TX
    #1 wart, Jun 12, 2014
    I ran across this on YouTube the other day. Kind of a commercial for SKF bearings but is has some interesting factory footage and info about the electric drivetrain, from a bearing-centric perspective.
  2. AudubonB
    AudubonB Mild-mannered Moderator Lord Vetinari*
    What a timely thread! I was thinking just yesterday "I sure hope TMC is not using Chinese-manufactured bearings in its motors". There is nothing like a single bad ball or roller in a bearing race to cause a cascade of failures that will ruin a motor.
    I have had (should write "had had") a good amount of interaction with Aktiebolaget Svenska Kullagerfabriken (SKF to the world) in decades past. Have the highest regard for their products, and am delighted to learn they're in every Tesla.
    Do you know how bearings used to be made? Specific masses of molten steel would be dropped from a shot tower into a pool of water at the bottom of the tower. The mass would achieve sphericity as it fell through the column of air. Nowadays, of course, it's the assembly line of thousands of nimble-fingered Vietnamese ladies with sandpaper..... j/k
  3. hobbes
    hobbes Active Member
    Germany
    Cool video, thanks for posting. Reassuring that Tesla uses high-quality components also where you don´t usually see them.
