Ski rack for X finally
Discussion in 'Model X' started by t56301, Jan 29, 2017.
Tags:
  1. t56301
    t56301 Member
    Was able to get it to work on the rear window so both my FWDs can open freely, as well as the hatchback. Setup is straightforward. And the low profile of the overall vehicle does help too - very easy to load and unload skis.
    I have tried different setups too, such as one rack on the spoiler and one on the rear window and have the ski tips pointing to the front of the vehicle. That works just fine but if you more than one pair of skis you can't keep both FWDs operable (if you only have one pair of skis, you can fit the skis within the middle trim to make both FWDs operable). Also you don't have much room to operate the hatchback.
    The ski rack is from seasucker.
    • Informative x 6
  2. larmor
    larmor Active Member
    Westlake, TX
    That's great. Any data on how it affects range?
  3. Blu Zap
    Blu Zap Grinning member
    San Rafael, CA.
    Sweet! Looks great! Good idea. How long skis can you put on before they hand out of the side? Good stuff.
  4. Nerdy_Engineer
    Nerdy_Engineer Brett - The Nerdy Engineer
    Colorado
    Awesome idea! I have the 6 seater so I ended up making a box for my ski for inside the car. I really like this idea though! I too would be very interested in hearing how much it affects your range.
    • Like x 4
  5. t56301
    t56301 Member
    I didn't bother to look at the data because honestly I didn't feel much impact at all. I was driving at the 70MPH rated speed most of the time.
  6. t56301
    t56301 Member
    Mine is at 60'' (I am short) and I could hardly see them in the side mirrors. You might want to measure yours and choose a different setup if needed.
  7. t56301
    t56301 Member
    Nice box!
    One the range, it is not really noticeable to me. Maybe it is because the whole setup is in the back.
  8. K-MTG
    K-MTG Sunshade Captain of TMC
    Irvine, CA
    Great video, are you on snow tires?
  9. xcell
    xcell MX Driver
    Switzerland
    I like the rack - although - does anyone knows if it meets European safety standards?
  10. flar
    flar Member
    Is that with the fixed spoiler? Would the active spoiler clear the mounts when it retracts?
  11. Carl
    Carl Supporting Member
    Belgium
    Seasucker racks are distributed in Europe in any case. I'm using one on my non-pano MS and it's really good. Certainly a lot better than the average 49.99 EUR suction cap racks which come with a "don't drive faster than 120 km/h" sticker yet somehow manage to pass EU safety standards as well :)
  12. Nerdy_Engineer
    Colorado
    Thanks! No, I'm still using all season tires. I'm looking into getting some winter tires, but I haven't yet. My Model X performs better than my old Subaru ever did so I'm not in a rush to get winter tires. However, I want to protect this car as much as I can so I'm probably going to get a set of winter tires just to be safe.
  13. Duckjybe
    Duckjybe Member
    Ontario, Canada
    #13 Duckjybe, Jan 30, 2017
    I was pleasantly surprised to discover that when you have 5 passengers in a 5 seater Model X you can put the skis inside with the tips under the 2nd row seats. I use the rear cargo cover in vertical position to support the tails of the skis. I can then put ski boot bags and gear in the trunk well. I fit our family's 5 pairs of skis up to 172cm (my 172cm skis are missing in the pictures). Longer skis like cross-country will also fit but have to go in at an angle. I didn't receive the flat floor cargo cover with my X but don't miss it yet.
  14. t56301
    t56301 Member
    Yes, mine is a fixed spoiler. I would not recommend mounting on an active spoiler as the racks are not that flexible :) But you can do what I did by mounting the racks on the glass only. You can always adjust the angles of the racks to avoid tucking the cups under the spoiler.
  15. rallykeeper
    rallykeeper Member
    Southern California
    Any thoughts on the maximum length ski that would work with this setup? I really like the idea of simply putting the skis on the rear window -- especially when I'm just driving back to our cabin from the mountain.
  16. Morristhecat
    Morristhecat Member
    Burnaby, BC
    This isn't for a Model X, but for my Model S I don't have the roof mounts for a ski rack, but I do have a hitch mount for a bike rack. I found a ski adapter for my bike rack on craigslist & it has been working great. I can't see why this wouldn't work for a Model X. It doesn't seem to add too much drag, and from the front is looks like a fin
  17. McManX
    McManX Member
    San Francisco, CA
    Some of us are looking for other options because this can get salt all over and ruin the skis.
    Mounting on the rear hatch should help a lot in this respect.
  18. Jeeps17
    Jeeps17 Cath Jockey in a P85
    Montreal, Canada
    Thank you very much for posting this !
    I have no local Seasucker dealer, thus cannot go look at their ski rack in person, but I have a few questions if you don't mind:
    1. When mounted on the hatch glass, can you hold skis together in pairs without the bindings of the bottom ski touching anything below (and same question when mounted on the spoiler) ?
    2. How many pairs of skis can you hold with the rack ?
    Thanks in advance!
  19. t56301
    t56301 Member
    Yes, I have tried it. The skis are actually pretty high up so there is no touching of the bindings on the glass, whether you set it up with the spoiler or not. If I am in the driver seat, I can't see the skis from the hatch window. No obstruction of my rear view either.
    Some basic info I got from seasucker on the rack posted here:
    Length (outside cup to outside cup) 33"
    Total Height 9"
    Clearance height 6.75"
    Our cups are 6" in diameter, so the width of the rack is technically 6"
    I would say it can at least hold 4 pairs in there.
  20. Jeeps17
    Montreal, Canada
    Thank you very much for your quick reply !
    One thing I have not seen on their site: The ski holders lock, but is there anything to prevent someone from releasing the vacuum cups and walking away with the empty rack (full would be a bit more work, but same concept o_O)?
