I am dredging up an old post (from 2015) but with a slightly different angle on the difference between the 19" OEM Slipstream and 19" Rial Lugano rims.
There were discussions about using this rim for winter snows and most of the comments were favorable. Last year I got a used set of snows and the Lugano rims were what the owner bought. I must admit I like this gunmetal color better on my blue MS and am considering swapping them - use the slipstream on my snows (4 months/year) and the Luganos with the Eagles.
Looking at the specs for both I see the Lugano weighs in at 32.0 lbs vs "29" for the OEMs and the Lugano has a 32mm offset vs 40 on the Slipstream. Three pounds (each) seems like I am going to take a hit in both performance (heavier rim/slower 0-60, right?) and economy (want max range/fill). Was wondering if some of those folks from 2015 are still on this board and might be able to weigh in on these parameters.
Also, I am wondering about the offset. The OEMs are 19x8.0 and the Lugano are 19x8.5. I assumed that the offset is due to this difference, but 8mm between the two seems more than what was needed (0.5 inches is 12.7mm /2 to center is 6.3mm) so I am guessing the tires will stick out more. Any thoughts on if this will impact driving dynamics (either good or bad) or wheel alignment (or is it too small to even worry about)?
Thanks.
Thanks.
