Slow discoveries, or How to silence the entry chimes
Discussion in 'Model 3' started by intjester, Aug 14, 2018.
  1. intjester
    intjester Member
    Oakland
    Old habits die hard...
    For safety reasons, it has been habitual for me to mash the brake pedal before doing anything else behind the wheel.
    In model 3, this turns the car on, flips to the driver setting from easy entry if you have that set, lights up the christmas tree widget icons along the top of the left side panel, and sounds a series of mystery chimes (because all the lights are flashing, who knows what the heck that sound is for?). This is not THAT different from how most cars start up, so I didn’t think much of it.
    For some reason today, I elected not to buckle my seat belt when driving from my mailbox to my front door and discovered that the chimes are simply a seat belt warning (they sounded a second time with only the seatbelt icon on).
    So, I thought, let’s try something novel and I buckled my seat belt BEFORE stepping on the brake pedal, and I got beautiful silence. No need to nag about a task you’ve already completed.
    Which now has me wondering if that would have worked in my old car...
  2. ebmcs03
    ebmcs03 Active Member
    So Cal
    Haha really?? I’ve got to try. I never noticed.
  3. RangerRick
    RangerRick Member
    Apex, NC
    Yeah, I have the same habit and I'm pretty sure I'll never break it, so I guess I'll just hear beeps until I die. ;)
  4. lairdb
    lairdb Member
    Bummed -- I thought you might have found a way to control the volume or timeout, or to entirely silence the chimes. (I find the seatbelt and door open chimes over-loud and annoying, e.g. when dropping off a passenger.)
  5. dhrivnak
    dhrivnak Active Member
    NE Tennessee
    I guess I always buckle first so I did not even know there were chimes for the driver. ;)
  6. TurboCJ
    TurboCJ Member
    Richmond
    @intjester I have the same habit of mashing the brake pedal and with the car being so quiet the chimes are annoying. Slowly learning to avoid the brake pedal on entry!
  7. rabar10
    rabar10 Model 3 >> Focus Electric
    Indianapolis, IN
    Easy Entry + buckling up before touching the bake pedal = seat belt squeeeeeze :confused:
    Have to keep some slack on the belt even after it’s buckled until after the seat has stopped moving, then let it tighten.
    Or just listen to a chime or two and wait till things have stopped moving around before buckling up :)
  8. compu85
    compu85 Supporting Member
    Springfield, VA, USA
    Yes. That's what the bonging is for, to remind you to buckle up. The DOT has required that since some time in the 70s.
    -J
  9. Reid
    Reid Member
    Redwood City, CA
    Yuup, every time I get in the car I think "dammit, why did I hit the brake before buckling my seatbelt?"
    I'm not sure I'll ever learn, though. I think other cars give you a brief period to fasted your belt, or don't start complaining until the car is moving. Don't quote me on that, though. This just seems far more intrusive and annoying than I'm used to.
  10. dgpcolorado
    dgpcolorado high altitude member
    The Western Slope, Colorado
    Depends on how one uses Easy Entry. I have it move the seat forward (and steering wheel forward and up, from all the way back) because I sit behind the B pillar and find it awkward to get out. So, yes, I usually buckle up before stepping on the brake pedal (and release the belt before hitting park). Perhaps I'm a minority of one...
  11. Tezlanian
    Tezlanian Member
    North America
    There's a lag between pressing the brake and the Model 3 allowing to you enter reverse/drive. I'll gladly take the annoying sound and continue to press the brake upon entering the vehicle so that it is ready to actually enter gear by the time I buckle.
  12. Pandamoanium
    Pandamoanium Member
    Colorado
    In our X and I think all Tesla cars, even if you buckle and start up when a passenger hasn't buckled. It will chime. Good actually in my opinion.
