Slower charging with 42.3?
Discussion in 'Model 3' started by aSlowOldGUy, Nov 4, 2018.
Tags:
  1. aSlowOldGUy
    aSlowOldGUy Member
    Orlando, FL
    Hello! I received 42.3 last week.
    I charge on a 20A 120V connection with the 5-20 adapter from Tesla. Up until 42.3, the app reported 7 miles per hour. Now, the app is reporting 6 miles per hour of charge.
    While this isn't TOO big of a deal (19 miles round trip to work) I was wondering if anyone has experienced any changes in their charge rate since the 42.3 update.
    Since app hit at the same time as V9, I'm hoping that the charge rate hasn't changed, but just how it rounds it / calculates it in the app.
    Anyone with any insight? A more conservative charge rate or is it something in the app, or is it just something else changed?
    Thanks!
  2. jdcollins5
    jdcollins5 Member
    Wilmington, NC
    I updated Saturday to 42.3 and I see no change in charging rates.
    What is voltage being reported while charging? If it is lower than 120V that will impact the mph rate.
  3. jasonh4451
    jasonh4451 Member
    San Francisco
    I’m on 42.2 and since upgrading I’ve noticed that the iOS app reports inaccurate charge rates. Inside the car seems normal. iOS app often shows a different % (like 79% when the car shows 80%) and slightly slower charge rate too.
  4. animorph
    animorph Active Member
    Scottsdale, AZ
    Could just be 7.0 changing to 6.9 MPH. Could be colder weather, though Orlando can't be too bad. I wouldn't worry about it.
  5. RayK
    RayK Active Member
    San Jose, CA
    Are you using an extension cord? My few times that I tried using one my rate went from 4MPH to 3MPH
  6. Falkirk
    Falkirk Member
    Toronto, Ontario
    I noticed this too, I wasn't sure what changed (I am now on 42.4) but I'm sure I was charging previously at 70km/h but now highest I've seen is 62km/h. I charge to 75%.
    Voltage and amps seem right (243v, 40amps) too.
  7. aSlowOldGUy
    aSlowOldGUy Member
    Orlando, FL
    I am, but that I've been using it since day one (well, day two). The only change was the software update.
  8. aSlowOldGUy
    aSlowOldGUy Member
    Orlando, FL
    Thanks, but nope - hit 58F here one night. Cold for us Floridians, but not exactly something that should impact the battery I'd say. Hit 80F today...
  9. aSlowOldGUy
    aSlowOldGUy Member
    Orlando, FL
    Thanks - reporting 120V, 16A, as expected. I'll keep an eye on it. Hoping it is a rounding issue.
