LargeHamCollider
Battery cells != scalable
I've said this before but batteries are not scalable, increasing cell size means decreasing power density (and charge speed, usually) all other things being equal.
I was expecting Model 3 will charge (in terms of power) slower than Model S due to less cooling capability.
And it appears to be that way.
If it doesn't taper more above 60%. My 90D charges best from 0-55%, after that it starts to taper.
My guess is Tesla has limited the charging speed using software. They can't have Model 3 charging faster than Model S and X.
At least until they upgrade the batteries in those cars. They will do this early next year IMO and at that time push a software update to the Model 3's that will allow all of the newer Teslas to charge much faster.
2170 is new form factor. Not new chemistry.I was expecting the Model 3 to charge quicker than todays Model S, due to improvements in cell chemistry. Remember the 350kW charging is childs play tweet from Elon? If 350kW is childs play, than what is this?
It's not the stall that costs lots of money. It's the power output. It doesn't matter is there 10x Model S's charging at 100kW rate or 20x Model3's charging at 50kW rate. Slight difference in parking space and stalls. Which does not cost a lot (sheet metal and some cables).There are going to be tons of Model 3s flooding the superchargers in a years time. It doesn't make sense that Tesla would chose a module format that does not allow for faster supercharging. I suspect these are conservative estimates.
350kW is charger power. Not stall power output. 350kW charger can supply 4 stalls with almost no limitations due to charger sharing.
Tesla US plug nor Enhanced Type2 plug supports amps any higher than S/X can handle today. Nor can passenger vehicles charge any faster that S/X due to limited onboard cooling capability. This is why S/X 90-100kWh packs sometimes throttle down. Heat buildup.
Should I remind people that no other electric vehicle charge as fast as base Model 3 (except Model S/X)?
With a 28kwh battery. Apples to oranges.
0-80% in 30 minutes. So 190 miles for a Model X 75D for example.
Yea, the Model 3 should actually charge faster...
I would guess another 'benefit' is to discourage supercharging for locals (or taxi/uber/lyft) abusing it? Good. They call the 310 car 'long range' to imply traveling.
Correct me if I am wrong, but doesn't Supercharging mean FAST charging?
Are we the guinea pigs who are going to be testing the new 2170 cells for Tesla?
Did the Model S 60 battery have a lower charge speed or did it also do 170 miles in 30 minutes?
And I noticed on My Tesla page that supercharging was listed as "pay per use" Where's my free 400 KW of Supercharging?
Small reminder, 90% of charging on Teslas is done at home. I think many folks overestimate the frequency in which they would exceed the vehicles range in any particular day.
