SageBrush
REJECT Fascism
Are they presuming a charge up to 100%, or at least past 80% SoC ? I bet that the final 80 to 100% SoC knocks down the average a lot.I’m very curious why the press kit understates charge speeds so much
So there is a picture in the production photos thread that shows a Model 3 supercharging. It states the range at 259 miles (83% of 310) but it is only charging at 30kW. Charging rate is 172 mi/hr. It also lists amps at 48A, vs the picture in this thread showing 106kW, 456 mi/hr and 42A, battery at 49%. (data was presented differently, I guess there are options how to display?)
Any thoughts? I realize there are many variables, but this is quite a bit less than the 70kW at 85% that @FlyingCookie claimed he saw.
As we know of at least one car charging to 100% = 334 miles, perhaps 259 miles indicated really was only 77.5%.The amp limit 48A/42A is only for L2 charging it has nothing to do with Supercharging. The mi/hr number is an average so it changes drastically as you charge and the rate changes. So you should just ignore both of those numbers.
Leaving you with:
83% @ 30kW vs. 49% @ 106kW.
Which is perfectly reasonable, you should expect the charge rate to reduce as the state of charge increases.
also screen at M3OC showed 64kW at ~58%, although no details about charging session maybe it was shared...So there is a new app screenshot of a model 3 supercharging session on that other forum showing the range at 184 MI (59% of 310), charge rate is listed at 53 kW - 233 mi/hr.
No comments regarding any specific issues with the charging session.
This is another data point that doesn't agree very well the 106 kW charging rate shown earlier.
Perhaps Tesla was doing something experimental with the fast charging car
100% is 315 miles.As we know of at least one car charging to 100% = 334 miles, perhaps 259 miles indicated really was only 77.5%.
Depends on whether this 334 was a pre-production anomaly or realistic for all production LR's.
I wonder if what I saw on that Model 3 was similar to the fluke I saw on my P85 a few weeks ago, where I plugged in at 44% SOC and saw 108KW for a few minutes before it fell down to the usual taper.
In my experience the 85 kWh taper is very rigid and I've never seen "flukes" where the rate exceeds the known maximum charging curve. 108 kw at 44% is about 20 kw higher then I've ever seen at this SOC. I'd be really interested if you could document the next time this occurs (or if someone else could that has also seen this behavior).
Do you recall how long it was between when it started charging and when you took the picture?he arrived at 37% SOC and you see the picture I took at 49% SOC.
I’m very curious why the press kit understates charge speeds so much... What i saw and what the kit says are certainly not the same thing.
I don’t know exactly off the top of my head, but I know it was less than 15 minutes. We spent about five or ten minutes chatting, and then he offered to let me sit in the car, and then I took a few picture of the interior at my friend’s request shortly after.Do you recall how long it was between when it started charging and when you took the picture?
Also worth noting is that in similar outside conditions, my Model S would have ramped the fans and compressor up to full speed after only two or three minutes at 116kw. The Model 3 hardly made a peep after 15 minutes at nearly as high charge rates.
Was 110 kW the highest charge rate you observed?
Model 3 Supercharging
% kW Time
0 0 0:00
10 115 0:04
20 115 0:08
30 112 0:12
40 110 0:16
50 105 0:20
60 90 0:26
70 85 0:31
80 80 0:37
90 60 0:45
100 40 0:56
Thoughts?
