Slowing down to 0 upon accelerator release
Discussion in 'Model X' started by angel99, Aug 12, 2019.
  1. Saghost
    Saghost Well-Known Member
    Delaware
    I drove with creep on the first several months, but eventually decided I like the control of creep off better.
    I always make sure vehicle hold engages every time I stop - it will stay engaged until I hit the accelerator or press the brake again (the car supposedly will shift to Park after ten minutes or so if just left that way or if the driver leaves the seat.)
    So it's like the car is heel and toe-ing for you.
  2. cucubits
    cucubits Member
    TX
    I'd say it's more like the car is pulling the 'handbrake' for you every time.
    I tried this on a drive test and I'm not sure I'd like to hear those little electric motors putting the brakes on every time I come to a stop in stop and go traffic for example.
  3. ajdelange
    ajdelange Member
    Virginia/Quebec
    No, not really.
    But you can make the field rotate relative to the rotor as fast as you want in either direction. Yes, you get into some hairy control issues when slip is greater than the breakdown torque point slip (IM) but in the PM motors you can position the field anywhere you want relative to the magnets and vary its strength in order to have torque in either direction relative to rotor position. There may be practical limitations and the control would certainly be more easily implemented by applying a bit of friction braking.
  4. Saghost
    Delaware
    But that's not regeneration any more - that's me powering the car in reverse now. To regenerate, I have to let the rotor pull the field forward, and you run out of headroom as the car slows down.
  5. Saghost
    Delaware
    ??? I don't hear anything when I do it, and I wouldn't expect to - the iBooster that is always active when you're braking provides the force for vehicle hold, just like it does when AP brakes and just like it does when you brake.
  6. cucubits
    cucubits Member
    TX
    Then this is different from the brake hold which is set when you press the brake pedal a little harder? That's when I heard these.
  7. ajdelange
    ajdelange Member
    Virginia/Quebec
    Nothing I said is to be interpreted as requiring any action on your part. I am simply pointing out that there are no fundamental limitations in these motors to prevent dynamic braking down to 0. They can produce torque (in either direction) at and near 0 rotational speed.
  8. V1VrV2
    V1VrV2 Member
    Longmont, CO
    Ah, good to know - I experienced a slight roll backward leaving the Delivery Center parking lot and that was enough to spook me - all of those new Model 3 and S sitting around waiting for me to crash into them with my new MX, felt like I was back in my manual gearbox driving days. :)
  9. Saghost
    Delaware
    No, that is the feature we're talking about.
    Not sure what noise you're hearing, but there aren't any extra electric motors involved in the brake hold, just the same one that provides the power brake assist during every stop.
  10. lakemirror
    lakemirror Member
    Polk County, Florida
    I think the holding brake has to be applied by a slight extra press on the brake pedal. I don't think it's automatic.
  11. Krazaak
    Krazaak Member
    Charlotte, NC
    That sounds more like the brake being applied in park, hill hold shouldn't make any additional noise.
    The motors can bring and hold the car to 0mph, but at the expenditure of energy, not recovery. So it's more efficient to use the brake to stop the car below the speed at which the energy recovered by regenerative braking.
    It's automatic with creep disabled, once the vehicle comes to a complete stop. Only creep requires the extra pressure.
  12. Phil Seastrand
    United States
    It's automatic on flat ground. If your on a hill, either up or down, you need to apply a little extra pressure to engage hill-hold.
  13. jboy210
    jboy210 Supporting Member
    Northern California
    Hill Hold looks like this on your dash. It should come on after a sec or less at a full stop. But be aware if you press the throttle or brake it disengages fast.
  14. DCGOO
    DCGOO Active Member
    Indianapolis, IN
    Try using TACC in stop and go traffic. Vastly less stressful.
  15. ajdelange
    ajdelange Member
    Virginia/Quebec
    #35 ajdelange, Aug 15, 2019
    No question about that. People seem to be overlooking the fact that there just isn't, practically speaking, any energy to recover as the car slows down. At 1 mpH its kinetic energy (~250 J = 0.069 Wh) is 1/100th of what it is at 10 mpH (25,000 J = 6.9 wH) and that's 1/16th of what it is at 40 mpH (400,000J = 111 wH.)
  16. mbp11
    mbp11 Member
    SF Bay Area
    Thanks for the information on Hill Hold. I now have a little more information.
  17. ebrown7b
    ebrown7b Member
    Los Altos, CA
    The brakes used to have a separate caliper / pad on the rear wheels used for the parking brake. My 2013 Model S (P85) has a distinctive sound when it engages the parking brake. At some point, that was removed in favor of just keeping the main brakes engaged for the parking brake. I'm also not sure if the separate parking brake was a feature of all models or just performance models.
  18. Saghost
    Delaware
    Yeah, but that's the parking brake. Vehicle hold isn't a parking brake function - it uses the iBooster to hold the main brake circuits engaged and the brake pedal depressed while you have the car stopped.
  19. V1VrV2
    V1VrV2 Member
    Longmont, CO
    Thanks for the explanation and pic, @jboy210!
  20. jboy210
    Northern California
    Agreed. Best part of the AP system.
    No Problem. Play with for a day and you too will be converted over to the dark side.
