Small crack in CF near the bottom pan by driver door
Discussion in 'Roadster' started by asgard, May 16, 2016.
Tags:
  1. asgard
    asgard Member
    I noticed a couple of small cracks on the carbon fiber at the bottom of the vehicle where the aluminum plate bolts are. Th see are about 0.25 inch, not too deep. Looks like I might have bottomed out on a speed bump as there are scrapes near the crack.
    How does CF behave with cracks?
    Do they spread with age? Fixing it may involve removing the entire rear panel and that could prove costly. Is it worth repairing? Looking for advice.
  2. MLAUTO
    MLAUTO Member
    SW Florida
    That is not a stress point so the cracks shouldn't spread. It would be a major undertaking to remove because it is bonded to the body and the rear bulkhead. If you are worried about it you could use some bigger fender washers on the bolts.
  3. Habious
    Habious Member
    Springfield, VA
    If you have time, could you take/post some pics of the cracks?
  4. asgard
    asgard Member
    Here is what it looks like. It looks like a small rock may have been kicked back from the front tires at speed.
    It's about 0.5in end to end.
  5. MitchJi
    MitchJi Trying to learn kindness, patience & forgiveness
    Marin County, CA
    #5 MitchJi, May 17, 2016
    Why not repair the crack?:
    carbon fiber repair kit - Google Search
    Maybe not:
    Are DIY Carbon Repair Kits Safe or Sketchy?
  6. asgard
    asgard Member
  7. MitchJi
    Marin County, CA
    I agree and in any case it should be much better than a bigger washer
    But I'd still I'd investigate the kits and CF DIY repairs a little bit before I did it, to be sure that I did the best possible job. I'd also investigate hiring someone to do the repair. It might not cost very much and the quality might be much better.
  8. wiztecy
    wiztecy Active Member
    It doesn't look bad and I'd just fill it in personally with a small resin coat, sand, wet sand, little primer, and then a quick overspray with a paint can of the matching color. Then run a buffer on it to melt / blend in the paint. Its also under the car so you don't have to be all to picky as if it was in a highly visible area.
  9. asgard
    asgard Member
    That turned out fine. It was not a crack in the CF but the top layer of epoxy had cracked. I've coated it with epoxy and now I need to find the matching color.
    Does Tesla sell the paint?
    Thanks.
  10. wiztecy
    I know Tesla sells the touch up paint, not sure if they sell the spray can. You can always find the matching Lotus color and order it online or possibly call / goto your local auto parts store to see if they have the matching Lotus color in a spray.
