The "Smart Meter" project has a simple objective: save the supply companies money as they don't need to employ meter readers.
The "Smart Meter" project has a simple objective: save the supply companies money as they don't need to employ meter readers. Eventually, possibly, they will take a reading every 30 mins and the rate charged will go up and down.
Don't they still need a manual check every couple of years? (Also to check that you haven't tapped the supply before the meter ...)They’re useful to open up some time of use tariffs which can be useful to you. Although we had a meter reader turn up out of the blue to read mine despite being with octopus and seeing the remote readings every half hour
I wouldn't. I'm currently having plenty of chats with Scottish Power over mine. After it was installed I've been charged the wrong rates and they will not refund me at the moment. I'm having to go through all the figures manually and calculate it before they will look at this.Hi
I’ve received an email from my electricity provider offering a free gas and electricity smart meter.
Are there any disadvantages of installing g it?
Did anyone have a bad experience and regrets getting it?
Smart Meter only gives you an idea one how much energy you are using, it doesn't submit meter readings, only every 3 months unless you push to submit. I found it a pain in the neck and wish I never had it installed.
That's not how any kind of smart meter I've heard of works.Smart Meter only gives you an idea one how much energy you are using, it doesn't submit meter readings, only every 3 months unless you push to submit. I found it a pain in the neck and wish I never had it installed.
Yes they do. Ours has been physically read a number of times since installationDon't they still need a manual check every couple of years? (Also to check that you haven't tapped the supply before the meter ...)
